The mudguard is manufactured from household tools and spare parts lying around and takes about 30 minutes to make and fit. The main structure is from an old scrap aluminum bike wheel. Since this is essentially a bike part it somehow looks okay and works well as a mudguard.
Remove these ads by
Signing UpStep 1Get your kit together
1. A glue gun and a glue stick.
2. A hacksaw.
3. A scrap bike wheel (I used a battered aluminum wheel, measuring 622x17x6106, The larger the diameter of the wheel the better as you want it to curve around your wheel. Adjust the size of your jubilee clip accordingly.)
4. A jubilee clip (i used a 12-20mm clip but the size of the girth of your scrap wheel will dictate which size you should use.You want the clip to be a tight fit.)
5. A metal file.
6. A spoke and nipple.
7. A piece of string around 330mm long.
8. A M6 bolt 40-50mm long.
9. 6 x M6 nuts.
10. A bendable sheet of tough plastic roughly 300mm by 40mm. (I had a small sheet of transparent thick vinyl lying round but you could easily use thick plastic from a bottle or other container)
comments
Add Comment
Wasagi
says:
Add Comment
