Step 2Draw and Cut out Window
(You can modify this to be just slits to pull your ribbon through or however you feel would work best for you. I just want to be able to see it as I generally take the spool out that I want to use and run off with it.)
- Here I've traced out a 6.5" by 1" rectangle in pencil.
- Now use the exacto blade to cut it. Please be cautious when doing this, use a metal ruler and take your time. Don't try to cut through on your first cut, make some light cuts first. This makes it so much easier and less likely you are going to be pushing super hard, slip and slice your finger off. (That would cause a lot of blood and pain, speaking from experience)
Add Comment
