3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Recycled Scanner Hack!
Step 4Prep the housings...
I drilled 2 - 1/2" holes in the ends of the boxes, one small hole in one box for the ac adapter wires and a hole for the switch. I mounted the Inverter in the main box with hot glue. I also used a 6volt - 500Ma adapter instead of the original. (Some bench testing may be necessary to determine the exact voltage required to fully light, yet not blow the fluorescent lamp.) Run the wires from the ac adapter into the smaller hole in the box. Install the switch. Solder the negative ac adapter wire to one end of the switch and solder the other end of the switch to the black wire coming from the inverter. Solder the red wire from the Inverter to the positive side of the ac adapter. You should add some heat tubing and tie a not in the wires from the ac adapter to keep it from pull stress.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2398
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
