Recycled, Steampunk Watch
Published
Introduction: Recycled, Steampunk Watch
 This DOES NOT WORK. If you have a broken watch and 30-45 minutes you can steampunk it, and give it as a gift. This is meant for a shelf, because it does not tell time. Also, I made this with rck_mtn_climber.
Step 1: Parts
 wire
pliers / wire cutters
broken watch
hot glue gun
silver and gold paint
Step 2: Remove the Wrist Straps
 Just pull 'em off
Step 3: Take Off Dial
 use pliers to pull the dial off ( it may take some strength)
Step 4: Remove Back Covering
 im not exactly sure how we did this so sorry
Step 5: Remove Outer Edge
 pry this off.
note: if your watch does not have this then you can paint on the gold ring at the end.
Step 6: Remove Glass Covering and Clock
 If you pry off the glass cover, the clock and some other parts will fall out.
Step 7: Add Screw for Dial
 if you were paying attention earlier and read the notes then this is the random screw. Just screw it in, but leave some hanging out.
Step 8: Fixing Up, and Adding the Section on the Front
 The clock's hands should have been removed. On the back of the watch, there will be this battery section. Use the pliers and more strength to remove the odd shape in the center. Cut the dial where the threads end. Then place the battery section and the dial over the center of the clock face. Add hot glue. Let sit.
Step 9: The Two Other Screws
 Screw two screws into the top where the wrist straps were.
Step 10: Putting the Wires On
 Cut off some wire and wrap it around the two screws we put on in step 9. Coil some more wire and hot glue it around the watch. Look at the pictures for more detailed instructions.
Step 11: Painting
 Paint the main body silver and the back and outer rings gold.
Step 12: Finishing
 Place the clock, the back, and the outer ring back on the main body.
Step 13: Finishing Touches
 FIx up the paint, and whatever else if you need to. If you don't need to then you're done.
    • Microcontroller Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
    8 Comments
    Someone once said "you can't just stick screws on something and call it Steampunk". That aside, what aspects of this make it "steam-" as opposed to "cyber-" (which it looks more like)?
    L
    not only that, but most(steam or cyber) have some amount of functionality....
    Now looky here -273c, art doesnt need to do anything but evoke an emotional response.
    Very clever.
    But this is not labeled as art, at least nowhere my mortal eyes can see.
    Even if the emotional response is anger at the author using words wrong?
     Im not sure how many on this side of the pond understand the steampunk style or its rules, I know I don't. I do however enjoy the creations. While this construction may not qualify as steampunk I think the "ible" itself is well done with lots of clear pics showing each step (ok some not so clear but what the heck..) I DO consider this a form of recycle sculpture and while it stands on its own it would be really cool incorporated into a larger project
    ok... i was bored, had some time and a broken watch soooo i dont really care
