http://www.instructables.com/id/Easy_To_Build_Stepper_Controller_from_a_Recycled_M/
I really built up the solder on the bottom and doubled some wires to carry alot of current because i didn't know what kind of motors I would be useing in the end.
I haven't tested the controller with a computer, but by running 5v across the connecter pins quickly it did make a stepper turn.
Pay no attention to my terrible soldering skills :-P
thanks in advance :-)
great job :-)
If you're still interested though, there's a drawing of how to do that at:
http://www.luberth.com/plotter/TIP120schematic.png
My stepper motors rated 0.4amps@12volts D.C.
That is 400 milliamps.
500 milliamps limit for ULN2003 chips.
Mine already has a about a zillion tiny blue steel chips embedded in the plastic from using it to run my lathe.
thanks
mike
i hope at least the diagram can help a little
just tell me if you need more info on this
The third axis should work, as pins 1,14,16, and 17 can be either input or output pins, as they're defined as "control pins"
the ULN2003 handles a maximum of 500ma per phase.....check the data sheet.............
I think it's a great circuit myself.....
Next what power source to use, how to hook up the motors to the circuit, and last, why wont this work with Mach3 software? Why only, turbocnc?
as for the scanner stepper motors look at there model sheet on the side u will see the company that makes it and its model number enter these in google and bingo but be warned u might not understand it
trust its complicated
Srry for my bad English, I'm Dutch...
