Step 3Putting it all together
You need to seal off the bottom of the tube so your activity notes don't fall out. I've found two staples are enough to do the job. There's no need to seal the tops if you place your tubes high enough that little hands aren't likely to dip in and cheat to see what's happening ahead of time. I've found that leaving them open allows you to change the activities around if your pre-Christmas plans change unexpectedly or bad weather forces you to postpone something you'd planned for outdoors.
Squash the end of the roll firmly, select a couple of tail strips and staple the strips and the two sides of the squashed roll in place. Repeat again for the second set of strips. One roll done!
Repeat these steps another 23 times. =8)
If you engage your helpers you'll be done in no time at all.
Add Comment
