Recycled Flower Pot From Tin Cans
Published
Introduction: Recycled Flower Pot From Tin Cans
I started growing some plants in a seed starter greenhouse. They were getting quite big, so I had to replant them into pots. Unfortunatly, I didn't have any proper pots around, so I decided to make my own.
Materials:
  • Tin can
  • Potting soil
  • Plant
Tools
  • Hammer
  • Nail or screw
Step 1: Clean Your Can
Clean your can from the inside, and peel off the paper on the outside. It might help to get the outside wet to solve some of the glue.
Step 2: Make Drainage Holes
To make sure you don't overwater your to-be replanted mini-plants, I decided to make some drainage holes into the bottom of the can.
Flip the can upside down, on a hard surface. Take the screw, place it where your want your hole, and hit it with carefully with the hammer. No need for much force, the holes should be rather small so the soil cannot fall through them.
Repeat as much as you like. Bonus points for awesome patterns.
Step 3: Replant
Fill your pot with soil, add the plant, and fill up around it. If you planted your seeds in a starter thing, like I did, try to cover it with soil, but don't get it up too high (or the starter thing too deep in the pot).
Step 4: Water Your Plant, Label, and Enjoy
Water your plant to compact the soil. You might need to add some more soil afterwards. Be careful, you might have dirty water leaking out the bottom, so don't do it on your $$$ dining table.
You can label the pot with a sharpie. Super useful, if you have many different small plants, that look all the same.
Place it in an appropriate spot for the plant in question. Remember you have drainage holes, so there might be dirty water leaking out the bottom of your pot, so place it on something that can get dirty. When in doubt, place it on a small plate.
    • Oil Contest
      Oil Contest
    • Backpack Challenge
      Backpack Challenge
    • Water Contest
      Water Contest
    3 Discussions
    In the US that would be a steel can, not aluminum. Soda and beer cans are aluminum and pretty much every canned food vessel is going to be steel. Your mileage may vary.
    Not sure how I got to aluminium can, but it seems like most of them are made of steel here as well. Thanks for the note, I'll change it in the instructable.
    very handy when you dont have a planting pot
