loading
Have you ever gotten sticker shock when you saw the price tag on that
harness that you saw in the store? Yup, I mean the kind of harnesses that us queer and kinky folk us when we want a little strap on action. Maybe it's time to learn how to make
your own. Btw, there's nothing explicit here, it's what you do with your toys that's a little on the rowdy side.
Step 1: Gather your tools
You will need:
One hammer
One pointy tool (knife or awl)
scissors
snap setter
snap setting anvil
Step 2: Anvil
This is the avil, the smooth side is for the round part of the snaps you will be setting. The other side is for setting the snap that interlocks with that snap.
Step 3: gather materials
You need
One two inch side release buckle
Four One inch side release buckles
One steel ring whatever size bust fits the toys you usually use. Mine is a two inch.
At least six pairs of snaps. You are likely to mess some up so have extras.
Nine or ten rivets. (you can use snaps here too, but since you don't need to adjust these points, I used rivets.
One skinny used bike tube
One fat bike tube.
Step 4: snaps
These are your snaps. The first picture is the smooth side pair which you set using the sooth side of the anvil in step three. The second picture is the opposite pair which you set using the side of the anvil in picture two of step three. I promise I will get to the construction details in a moment.
Step 5: how to set snaps
To set snaps, you will poke a hole through the materials to be joined and inset the snap post through the hole. Lay the top part of the snap on over the post and put the whole thing on the proper side of the anvil as illustrated in 3 and 5. Place the setting tool on top of the post with the nubbin down and centered. Hit the anvil with the hammer as needed until the snap is secure.
Step 6: Cut and assemble the butt straps.
Cut two twenty one inch strips of thin tube. Set one pair of snaps into the end of the two straps as illustrated. Slide buckles on opposite end.
Step 7: Waist straps
Construct waist strap. Cut two twenty three inch lengths of thick tube. Set two pairs of snaps into the end of each as illustrated. Attach the receiving two inch buckle to the end of one strip by pressing the rivets together with pliers or using snaps if you want. Loop the corresponding buckle onto the other strap. We'll make the butt strap attachment points in the next step.
Step 8: Butt strap attatchment points
Cut two eleven inch strips of thin tube and rivet or snap as shown.
Step 9: Assemble the whole thing!!!!!!!
Heres a picture of how it all comes together. Wear your new harness for great play, and be sure to have safe sex. The tails can be trimmed once you've fitted it, or you can leave them long so that they will fit a range of body types.
<p>Is there any pre treatment on the tubes?<br>Cause you know tubes can be dirty and the dirt is not the fun one.</p><p>Awesome DIY </p>
Some one needs to make one of them machines that people can attach their toys to and it gives the thrusting actions. I can't seem to find anything of the sort anywhere online, without paying high prices anyways. But thats what instructables is all about, gettin by, without the prices
Try a jigsaw but reduce the ac voltage with a transformer down to about 40-50 volts to slow it down some or use a 120v light dimmer switch. take take the guide plate off the bottom, grind the teeth off an old blade. Drill a blade size hole down the center of a dildo, fill it with glue,(liquid nail) and insert the blade. When it is FULLY dry insert the other end of the blade in the jigsaw(or saws all) like normal. TEST IT FIRST, If its slow enough and sturdy then put it to use, AFTER WASHING IT...
I know your comment is a few years old, but I still feel the need to say that it is very dangerous to put a blade of any kind into an object that will find its way inside the body. There are reports of the horrors that can befall an individual who attempts this. If time and tools aren't a factor, an attachment for a reciprocating saw or a jigsaw can easily be made so that it operates safely. The other factors on that comment are correct though.
youre right. but thats why i mentioned grinding the teeth off of it. however no one without good sense should attempt it. which rules out most citizens, lol. thank you for your comment and concern<br><br>
It is really easy man, the mechanism is like on the old steam train engines. Build a frame round that and you are good to go.
I can't imagine that such a machine would be very difficult to make. It couldn't take more than an electric motor. I've always thought that they looked kind of painful though, I mean it seems like there wouldn't be enough feedback. Maybe if you could figure out a way to vary the thrust depth and speed via remote. I don't know though. Anyway interesting thought let me know if you make one.
I would love to try making one, but i am a computer geek, not a mechanic. I dont know crap about motors, gears and the like. If anyone needs a computerized one programmed, i could probably help, but im not gonna be able to make one, with out blueprints from some one else
Any suggestions on where to best find 2&quot; closed jump rings?
I got mine off ebay, really good quality, pretty cheap and fast delivery perfect for this instructable as i used them for mine. hope this helps.<br> <br> <a href="http://www.ebay.co.uk/itm/310384022685?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_508wt_1185" rel="nofollow">http://www.ebay.co.uk/itm/310384022685?ssPageName=STRK:MEWNX:IT&amp;_trksid=p3984.m1439.l2649#ht_508wt_1185</a>
i'm so glad i found this. i have a friend who used to make these at a skillshare but alas she moved before i could get a lesson. cheers.
Thank you! It feel super awesome and tight. really easy to do. It is little hard to adjust buckles, larger size buckles might fix that.
Nice, I've been looking for a dildo harness, but nothing caught my fancy. Just make my own then.
very useful template. thanks for posting. the design also works (with minor adjustments) with cheap canvas strapping found in most hardware stores. when neither a sex shop or bike tube are available.
Sweetness (=<br/>FYI, if you are using an awl or ice pick to punch the holes for your rivets, that could have something to do with the rubber tearing there. A better option would be to use a proper hole punch for the job. <br/><br/>You can get a cheap set of hole punches from most tool stores, or make your own out of a piece of old brake line. <br/><br/>A hole punch will cut a clean hole, where a solid object, no matter how sharp, tears its way through, creating areas of weakness around the hole. Once you start a tear in rubber, it just wants to keep tearing. <br/><br/>Also, &quot;rubber cement&quot; from the crafts store, as advertised, works quite well on rubber- it can reinforce your riveted areas, or be used to add a lining if the hardware becomes uncomfortable. <br/><br/>Finally, if you want to experiment with larger pieces of rubber for other... toys... some motorcycles (usually dirt bikes and cruisers with wire-spoke wheels) also use inner tubes... and these can be quite large and sturdy. <br/>
Buy a cheap tire repair kit and use the cement from that. It will work much better. I've used rubber cement and a patch to repair a bike tube in a pinch, and while it worked, the patch didn't last.&nbsp;
I was reading this when my roomate read over the title over my shoulder and said "this guy is an idiot, you can't rappel with tha... nevermind." Now he's looking at me funny.
I thought that for a minute to haha lol though that is what I was looking for though this is interesting haha.
does that mean that people going rappeling go to the sex shop first?
im_tux, I suppose if your fetish is exploiting fear of heights, then yes!
it's for dildos babe
Do you think it can be used for a double ender or with two dildos put together using a coupler?
WOW. This is amazing. My friend and I really want to start making this. You know you're the only tutorial we've found on inner tube strap-ons? Are there any other sources of info on it? Thanks!!!
<em>&quot;You know you're the only tutorial we've found on inner tube strap-ons?&quot;</em><br/><br/>Somehow I don't find this too surprising.<br/>
Thanks for this Instructable. I made one for my wife, she loves it. I did a few things different. I didn't have any snaps or rivets, so I glues and sewed. It's a lot sturdier than I thought it would be. I have a few modification ideas I may try later.
I'm glad that the my instructions helped you out. It makes me happy to see people using these instructions and modifying them. If you have improvements or pictures we can collaborate and put them into the instructable. enjoy
This site needs more sexual content.
You'll have to get that on your own. I'm just here to teach you to make the toys.
I'm starting a group.
Here it is!<br/><a rel="nofollow" href="https://www.instructables.com/group/kinky/">https://www.instructables.com/group/kinky/</a><br/>
Hey, thanks for the praise, I unfortunately don't know of any other tutorials about it. Enjoy.
I'd love to try this. I only need to find a chick to play with. D=<br/>
Nice! It's hard to find a good vegan harness. Is there any reason you can't use snaps around the O-ring so you can swap it out for different girths?
I think that you may not have looked close enough. The harness I built does us snaps to hold the ring so that you can interchange it. Happy making.
what kind of rivets are you using? some kind of clothing rivets?
Tandy leather no. 1273-12 rivets. Since I made this though, I have been thinking that it would be best to sew the points where I previously used rivets. That part never has to come apart, and the rivets tend to pull through after heavy use. They don't have a big enough flange to really hold well. I would now suggest a needle and thread.
good job on the instructable.. I would think the back of the rivits and snaps would be a little cold on the skin ? or might grab a little hair. Have you thought of a way to cover them? great recycling .. Do you armor-all the rubber or anything to seal it?
Hey, I hadn't ever thought about covering the snaps or rivets because they always warm up quickly for me, and because I don't have any hair to speak of where they ride, but that's a good point. I wonder if a little bit of shoe goo around the backs of the snaps would do the trick. Do you have any ideas? I could add a note about it if we come up with something good. I haven't used armorall or anything to seal the rubber, but that might be a good idea too might even make the harness a little more shiny. I worry about something like that being reactive with skin, latex or silicon though. Thanks for the comment.
Put an inner tube patch over them
Excellent idea! and good to see on instructables!
Tyra Banks would look good in this, me...not even close, besides i like things in working order, neat idea though.
Not a man's harness I don't think.
For a mere $19.95, plus shipping and handling, you too can reach those high notes with "The Soprano". Just pull the buckle back, and release. So easy it almost works itself. Dishwasher safe, no unsightly panty lines. Call now. Operators are standing by.
you sir, are a god
innertubes are stinky too...hehe
Hey! that is a snazzy harness, and an excellent use of inner tube. Just the other day i was telling a friend that the uses for recycled tubes are ENDLESS. I'll pass this on : P.
About This Instructable
88,023views
163favorites
License:
More by ljacts:Recycled harness (hot things to do with old bike tube)
Add instructable to:
