harness that you saw in the store? Yup, I mean the kind of harnesses that us queer and kinky folk us when we want a little strap on action. Maybe it's time to learn how to make
your own. Btw, there's nothing explicit here, it's what you do with your toys that's a little on the rowdy side.
Remove these ads by
Signing UpStep 1Gather your tools
One hammer
One pointy tool (knife or awl)
scissors
snap setter
snap setting anvil
FYI, if you are using an awl or ice pick to punch the holes for your rivets, that could have something to do with the rubber tearing there. A better option would be to use a proper hole punch for the job.
You can get a cheap set of hole punches from most tool stores, or make your own out of a piece of old brake line.
A hole punch will cut a clean hole, where a solid object, no matter how sharp, tears its way through, creating areas of weakness around the hole. Once you start a tear in rubber, it just wants to keep tearing.
Also, "rubber cement" from the crafts store, as advertised, works quite well on rubber- it can reinforce your riveted areas, or be used to add a lining if the hardware becomes uncomfortable.
Finally, if you want to experiment with larger pieces of rubber for other... toys... some motorcycles (usually dirt bikes and cruisers with wire-spoke wheels) also use inner tubes... and these can be quite large and sturdy.
Somehow I don't find this too surprising.
http://www.instructables.com/group/kinky/
