3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Recycled receipt notepad
Ever gone through your wallet or a draw at home realising you are neck deep in useless receipts? Well if the taxman ain't knocking then you need to do something about it. Sure you could trash the things, but what about some creativity instead?
This Instructable is how to make a notepad using basic things you will probably have around the room you are sitting in. This is what you will need (at max):
- Some old cardboard (I enjoy cutting up the flaps off boxes)
- A bunch of old receipt dockets
- Two small metal binder ringers (usually from a stationary store or just at home in my case) or a length of ribbon/cotton/yarn/stringed such.
- Scissors or a blade
- hole puncher and single hole puncher aka a pen
Step 1Measurements
Measurements
Once I gathered my receipts I noticed that all of them had a width of 8cm, which is brilliant as it will help create a compact notepad you can take anywhere in your pocket. The only bad thing (if it is for some people) is that receipt lengths will always vary. This means you should organise them into a neat pile and then decide how long you would like them. This effect didn't worry me and I went with the common length of mine which was 19 cm. Once you have a good pile of one sided and same width pieces you can thus... CONTINUE---->
10 comments
Jan 12, 2011. 3:44 PMPuzzleJenn says:
About six months ago (July 2010), a study was published about receipts containing BPA. I'm gonna go out on a limb and say this might not be such a good idea in light of these findings.
http://www.sciencenews.org/view/generic/id/61764/title/Receipts_a_large_%E2%80%94_and_largely_ignored_%E2%80%94_source_of_BPA
Great idea to reuse scraps of paper, but I'd rather not expose myself to any more bpa than necessary. :(
Dec 28, 2009. 1:14 PMhishealer says:
I used to do this when waiting tables and I would run out of blank paper.  I would take the reciepts out of my pocket and staple them together, then write on the back.  Necessity really is the mother of invention.
Also, the pens don't matter so much if you are just using them for a scratch pad, but ball points do smear on thermal paper.  No one could tell because I washed my hands so much though!
Apr 23, 2009. 8:40 AMjpj331 says:
If you spray the receipt with Lysol or some other compressed liquid(such as Axe) it'll remove most, if not all, of the ink. And it'll smell good.
Jan 22, 2009. 1:24 PMpossupply says:
This is a cool idea. The company I work for sells <a href="http://www.possupply.com/Thermal-Paper-Rolls">Thermal Paper<a/>. Thermal paper rolls are coated with a chemical that changes color when exposed to heated print heads. Therefore, thermal paper does not require ink to produce an image. You can stratch the top of a thermal paper with your finger nail and it will produce an image.
You can also scan your receipts using NeatReceipts (http://www.neatco.com/products/neatreceipts) to store your receipts digitally.
Jan 20, 2009. 3:50 AMPhil B says:
What type of pen do you use when writing on the backs of your receipts? Most of the receipts we get are on thermal paper. I generally use a fountain pen, and those often skip on thermal paper. Even ballpoints often do not work well when signing for a credit card charge in the store.
Jan 20, 2009. 5:57 AMjessyratfink says:
It'll actually work if you're writing on top of another piece of paper. It's very odd. We're constantly giving people things to sign on top of where I work.
Jan 20, 2009. 5:08 AMPKM says:
A lot of the receipts I get are actually pressure-sensitive paper (used with a dot matrix printer with no ink ribbon), so you can write on them with a fingernail/key/empty ballpoint/knitting needle. The downside is they also appear to come with advertising on the back (who reads the back of their till receipts? Srsly...).
Jan 20, 2009. 1:32 PMNesagwa says:
They put coupons back there!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:toil_and_spin
