Recycled Scrap Metal Sheep // Mark II
Introduction: Recycled Scrap Metal Sheep // Mark II
After having already mad a scrap sheep last summer, and with all the positive comments received as a result of it, i decided to make a new one! This time I took photos throughout the making process. I hope you like it!
Step 1: Step 1: Sourcing the Metal
As an agricultural contractor, my dad is forever buying new parts for farm machinery, which often leaves the scrap bin brimmed full with old useless metal parts. Many of these parts are what are known as tines; spring like metal coils with long extensions. These then became the base of my sculpture. Each tine had to be steam cleaned and cut to size, then the paint ground off to allow for welding.
Step 2: Step 2: Assembling the Frame / Legs
The sculpture would be extremely heave, and so it was essential that the base frame was solid. A pair of 'legs' was welded to each end of a thick bar, then supportive smaller rods welded to these. The spring sections were then welded around this to form a 'belly' and an arch for the girth of the body.
Step 3: Step 3: Filling It In
Now it was a case of building up the body, a rather tedious task! Each spring was steam cleaned, grinded and welded into it's specific place.
Step 4: Step 4: Making the Head
The head was perhaps the most tricky part. Two springs were heated using a gas torch, then pulled and distorted to form horns. Smaller springs were used to form the main nose arch, then larger springs to form eye sockets in which a bolt would be welded to form the eye. To attatch the head to the body, a thick rod was welded to the inside of the chest of the sheep up to where the head would be, then the head was welded to this. The neck was then filled in with the remaining springs.
Step 5: Step 5: Final Touches
Finally, the whole structure was set alight (in a controlled manner of course!) to remove the paint, which will now allow the sheep to rust and create that rustic outdoorsy look.
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    Not sure if this is "baa baa black sheep" or the "spring lamb", great work though well done. Incidentally my name is Alan and I take care of maintenance here at work , also have a guy here who constantly breaks things (keeps me going!) we call him "jungles" (thick, dense and impenetrable) not very PC I know but the name suits him and he is proud of it!!
    A very impressive work of art, well done. I am ever so slightly envious. Did you name your sheep?
    Also you may want to consider purchasing a cheap sand blasting cabinet to save work on steam cleaning, grinding and then burning off paint. There is at least one instructable for a knock down sand blasting cabinet made using a bulk bag.
    Its currently un-named, however the last one was named Alan after the guy who broke the machine with the tines! Yes we do in fact have a sand blaster but its more industrial and I don't know how to use it yet!
    We have a guy like him at work, we just call him Hammer, because he breaks things. Keeps me in a job though.
    That is pretty sweet and that last picture makes it look so epic!
