Recycled workshop organzier by liquidhandwash
Featured
Step 3: Cut containers in half
This is pretty easy just grab a jigsaw and cut the containers in half. There is a seam that you can follow all the way around and they cut easily with a wood saw blade.
Some containers have a deep recess in the bottom and can be difficult to cut all the way around with a jig saw. I cut as far as I can go in one direction then turn the container around and start again from the other  direction. Using this method I can usually get the saw to cut through the recess.
Once in half you can wipe out the oil or wash it out. You can also sand the edges, but I don't bother.
If you choose to use a container that's had chemicals in it it would pay to wash it out before you start cutting it and wear gloves and goggles.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
