3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Recycling your old dimmer switch as a variable temperature control for your soldering iron
I have seen a lot of professional variable temperature control for soldering iron, but too expensive. So I make one out of an old dimmer switch, outlet, gang plate and plug which already been junk and some old PVC switch box that came with it and some leftover wire from the rewiring work of our house...voila a simple and effective variable temperature controller for your soldering iron and it doubles as a dimmer for your lampshade if you want.
Step 1Materials needed:
Materials needed:
  • last photo ←
recycled dimmer switch preferrably 500Watts max the better
old gang plate
junk 3 gang universal outlet or any available
recycled PVC switch box
cutter
universal screw driver with bits or plain old screw driver will do the trick
long nose pliers
soldering iron(optional)
1 meter flat electrical wire
old plug from junk appliances I found on the trash bin
9 comments
Sep 28, 2009. 9:21 PMhore says:
usually where can we get dimmer switch,and gang plate.
Jun 12, 2011. 12:48 PMdhackaray says:
at a hardware store
Jul 26, 2009. 1:59 PMara says:
Great! Just few minutes ago I was thinking how to use a soldering iron for other projects than electronics (to cut plastics, burn wood, etc.). Your ideea come at the best moment. Many thanks and apologise for my poor english. Ara from Romania
Sep 30, 2010. 3:55 AMtaye says:
can you help with final year project designs schematics for electronics students thanks.
Mar 26, 2010. 1:55 PMdylabong says:
would you be able to instead of using 1 meter flat wire  a plug and 3 gang, just use a 3 gang extension cord? if not could you explain a little bit better how the plug is connected? are both sides of the flat connected to it? thanks.
Dec 1, 2009. 7:01 AMhore says:
if i change soldering iron with hair dryer will it work, is it dangerous.and do you think hair dryer can produce more heat.
Oct 3, 2009. 8:19 PMWazzuplol says:
i got a suggestion. do you know those wireless light dimming systems? try to do this with thos that would be awesome
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:inertia18
A graduate of BS.Information and Communications technology, taken up chemistry for 3 years, also taken Community development for 2 years. A graduate of TESDA Commercial Cooking (NC2 certified) and A ...
more »
