3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Red Oak Pyramid Bow
Step 11Just an Update
Just an Update
So, it's six months on.  The bow has held up well, I've been hunting with it several time, unsuccessfully, but that's not the bows fault.  After all this time it's developed about an inch of string follow, nothing to worry about. The weight is still up there above 50lbs, I measured it before the season just to be sure. I did have one small problem, the first day of hunting was ninety degrees and one hundred percent humidity, I sweated so much the grain raised on the handle, that was a quick fix with a bit of sanding.
I also added a "razzle dazzle" bit of camo by zigzagging painters tape on the bow, and rubbing in burnt cork, followed with another wax coat.
2 comments
May 27, 2012. 11:49 PMjmichelin says:
Beautiful bow man, im thinking of making one like it myself, the same style
Mar 30, 2011. 12:21 AMlwulfe says:
is there a way to make the poundage less such as somewhere between 30-35 pounds?
Apr 25, 2011. 5:05 PMthebair says:
Shave off more wood from the belly of the bow.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
258
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
