Step 5The handle
Start by cutting the saved 25 inch piece to 9 inches. Now using your table saw carefully feed the piece back an forth across the blade while raising the blade in small increments. the feather edge should be tangent with the highest point on the blade. you can make a simple sliding jig to ease the process, I didn't, but would recommend it. Also I used a 7 inch blade, a 10 inch would have made nicer fades.
Don't worry about getting a perfect paper thin edge, but get close, now you can glue the handle piece to the bow and let it dry at least 24 hours, and then cut out the handle.
In my experience, the crucial element to getting a good bond is really good clamping. Personally, I use Titebond II for most of my woodworking. I like its yellowish color, ease of cleanup and strength, and it's half the price of Titebond III. In my experience, it is incredibly strong when you clamp it well for 24 hours. In my fairly small experience, the glue-line will be stronger than the wood, so if the joint breaks, it won't be through the glue--it'll be the wood near the joint that breaks.
However, I haven't made a bow, so the flexing of the wood may make a different glue more appropriate.
Even with Elmer's white glue clamped properly, the joint should be stronger than the surrounding wood.
Try it. Edge glue some scraps and try to break it. You'll see the wood fails before the joint.
