EZ-EL Wire Red Vintage Motorcycle Step-By-Step Tutorial
2,257
Published
Introduction: EZ-EL Wire Red Vintage Motorcycle Step-By-Step Tutorial
About: Electroluminescent Wire is an amazing technology. Working like a fluorescent light bulb in wire form, it can be applied to just about anything. The possibilities are endless; you can bend it, cut it, splice ...
This vintage red motorcycle is rimmed with flashing red LED lights. Definitely a head turner for night riders.
If you like tutorials like this, get more inspiration at https://ez-el.com/tutorials
Enter coupon code INSTmotorcycle at checkout for a discount!
Or if you prefer a video tutorial:
Materials:
1. (1) EZ-EL LED Wire kit
2. (1) EZ-EL Battery Kit
3. (3) LED light strips
4. (4) LED Extension cords
5. (2) Y-Cable
6. (1 Box) Alcohol Swabs
7. Motorcycle!
Step 1: Safety Precautions and Light Testing
As a safety precaution, disconnect the battery of the motorcycle (located under the seat).
Note: Don't burn out the battery with the LED Lights.
If the wires and the strip doesn't light during connection, turn the LED connectors over. Afterwards, connect them to the battery.
Don't force the input and output connectors, they will work once they are properly connected together.
Step 2: Designing the LED Pattern
Layout the LED Strip on the side of the motorcycle or hold out the LED strip for design ideas.
Note: Before installing the LED lights, plan out the design in order to know the length of the wire.
Step 3: Cleaning and Installing LED Light
Wipe down
Before mounting the LED wire, wipe the area down with alcohol wipes in order to remove any dirt or residue.
Putting LED lights on
The mounting process begins under the hood of the wheel. Start off by peeling the protective vinyl of the LED strip. Continue this as you go along the hood of the tire. As shown in the picture.
Note: Make sure that the area where the LED strips are going to be placed are clean. A cleans allows the LED strip to stick properly.
Step 4: LED Extension Cable
Run the LED strip and extension cables along the frame until you reach the battery.
Step 5: Zip Tie Cables
Once the connections are done, use the zip tie to secure the excess wire ad place them inside of the bike pouch.
Note: Make sure all connections and zip ties are secured and clean.
Step 6: Connect Cables to Battery
"Control Box"
Connect the wires to the control box and then place it under the seat. Make sure it is secure and hide it away from exposure due to possible water damage.
"Batteries"
Now connect the control box to the battery by connecting the outputs and inputs to the corresponding colors (black to black, red to red).
Step 7: Final Look
Once all of the connections are complete, go ahead and use the wireless remote to light up your bike!
!#@POW!@#! Now you've got your own light show!
If you liked this tutorial, get more inspiration from http://www.ez-el.com!
    • Microcontroller Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    3 Comments
    Really diggin' this one! Vintage with a modern twist, love it.
    I like your style, it's quite subtle, but really effective.
    Thanks! I'm glad you enjoy it!
