Redesign Your Snowboard With Self-adhesive Foil
5,200
7
12
Published
Introduction: Redesign Your Snowboard With Self-adhesive Foil
I recently swapped snowboards with my boyfriend and I was not totally satisfied with the design.. it was a bit out of date... so I thought I could probably change it a bit. I was not convinced by coloring the surface, as the color goes off and the whole procedure takes quite long - and in this case I didn't have the time for that. The only possibility that came to my mind was using self-adhesive foil, which also has the advantage that my boyfriend can remove it again, if we ever swap back :)
Step 1: What You Need
If you also want to give your board a new style, this is what you need:
1) a snowboard of your choice
2) self-adhesive foil - I bought mine in the paper shop for about 5€. I would suggest a rather thick (=strong) one, if you have the choice, but not with a structure like the one that imitates ridged metal.
3) cloth to clean the surface
4) cleaning liquid - my DIY-shop couldn't offer me anything that convinced me. The guy wasn't sure if it would destroy the plastic surface and I would have had to buy 1 liter.. for that it was too expensive. I used nail polish remover (Acetone) instead - 99 cents
5) a cutter
6) transparent nail polish (99 cents) - or any other varnish to seal the edges
Step 2: Surface Treatment
later. Withall I removed the bindings. Then I cleaned the surface, first with water and then with acetone to remove grease and oily substances. If you have a step pad that you don't want to keep, remove it also.. I kept mine, which made it a bit more difficult to apply the foil later.
With the cutter I worked a bit on the uneven areas where other edges destroyed the plastic. Sandpaper could also help here.
Step 3: Foil
Precut the foil. It should be some centimeters wider than the board, but not too wide. If it is too wide it gets harder to work with the foil, because you don't see where the board ends.
Then start sticking the foil to the board. I started on one end and cut it in the middle, because it was hard to cut it more or less precisely around the step pad. Make sure that you have the foil straight on the board. The best way in my opinion is to stick the first few centimeters to the board and then unroll the foil (still with the paper) to see if everything is covered also on the other end ;)
Take care that you don't get air bubbles!
Step 4: Cutting
If the foil of your choice covers your board, make use of your cutter. To be honest, this step took a bit more time than I expected. The most effective way is to cut along the edges holding the cutter on a +-45 degrees angle. Just slide the blade over the egde - in this way you obtain a quite clean cut. On some places I had to cut of more, because the edges were damaged and the foil doesn't stick well on these places.  Basically you have to cut so much away that the foil doesn't lift anymore if you wipe your finger over the egde.
Don't forget the holes for the bindings.
Step 5: Sealing
When the foil doesn't lift anymore you can seal it with the transparent varnish. Apply it as thick as you can with a small brush and take care that you don't get any drops where they shouldn't be (for example inside the holes for the bindings).
Step 6: Mount & Try
After the varnish is dry the bindings can be mounted again. I decided to stick some stickers on the "wooden" surface (obviously I couldn't get a lot of them in this moment). I think it would also be interesting to make a decoration on this background with a cutplott. That's what I will do on my next restyle try :)
The first an last step now is to ride it and see if you've done a good job!
Step 7: Test & Last Changes
I wasn't sure if the foil will stay on the board, but after 6 days of riding it I can say that I'm very satisfied. I was scared that everything will go off because of hard slopes, melted snow or the cold. After the first day, some millimeters of the foil lifted, but I just cut that piece off and resealed it when it was dry and now it's perfect. Of course a bit of the original color is visible, but you don't see that from further away. A bit of foil also scratched away on the part where the binding touches the surface.
All in all I am very satisfied. For the 7 euros I invested I got a surface that doesn't brake my designers heart and many compliments for my "new" snowboard :)
If you try this technique as well, let me know about your experiences and improvements!
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    12 Comments
    Sorry I'm commenting so much.
    I have a dark board, would you recommend putting on a white adhesive before putting on the new design?
    Should I put a clear coat of self adhesive on top?
    glad you like the idea :)
    you are right, the foil is called contact paper - i dont remember which brand i used, but for example d-c-fix is a quality brand (http://www.d-c-fix.com).
    i think it depends on the foil if you have to add another layer on the dark background. the one that i used was thick and would've worked perfectly also on a dark board! but i know that there are also quite thin foils... and about the clear coat on top - never tried it, but I dont see a reason why it shouldnt work actually. my recommentation is: just try it out - in both cases. Contact paper is not such a superexpensive material, so if it doesnt work out, you can just rip it off again. Might be a bit of work, but in general you should be able to remove all the glue residues with some alcohol or something from such a hard and even surface - how easy it is to peel it off also depends on the quality of the contact paper.
    Dont forget to share your results and experience with us! :)
    I have had the best revelation ever- plain background color on top of the board. Then some wall decals, which you can get in aaaaalllllll sorts of designs, then a clear sheet over that. I'm super psyched.
    some pieces went of between the bindings the first 2 day, but i always glued it back on again with nail polish and since that i didnt have any problems anymore! but i also have to admit that im not a heavy snowboarder - i use my board 1 week max. per season :)
    That about my usage too, so I don't think it'll be too bad
    Lemme know how the edges hold up....Ive done this before w many types of media, and the edges get destroyed in one day of riding. My nly solution that has worked is using the graphic material i use on my dirtbike....its 22mm thick
    FYI for readers- this stuff is called Contact Paper. Look that up and find many decorative ones :)
    Thanks SO much for this tutorial, I've been having idas like this but with sticker paper- this is so much better
    Questions! How hard is it to peel off the adhesive?
    What is the adhesive called exactly, and where would I get it? Did that design you had come with it?
    Literally came here to find out how to redesign a snowboard- this was sitting on the front page.
    Where does one get self adhesive foil? craft stores or hardware stores?
    i bought it in a shop where they sell paper and office goods.. i could buy it there cut from the roll.
