to see how I used PVC pipe to connect one barrel to the next in tandem. At the end of that tutorial I mentioned that I applied the lessons learned on the two barrel system I had at home to the three barrel system at the garden shed.
We put up a 12 foot gutter along the roof line at the back at the back of the shed and used a traditional downspout to send water directly down into the first barrel. We were lamenting the fact that we were only collecting half the water that was possible but were concerned about how we would get the water from a front gutter back to the same set of barrels. We definitely did not want to have barrels out front where they could be easily seen. After thinking about it for a while, we decided to use PVC pipe to solve the problem.
BTW, this very same shed is the target of another instructable where I showed how to install solar panels from Harbor Freight on it. You can see this at: http://www.instructables.com/id/How-to-mount-a-solar-panel/
Remove these ads by
Signing UpStep 1Materials needed
All pipes and connectors are half inch here.
A gutter that ends in a flat end piece
A PVC connector that is threaded male on one end and non-threaded female on the other end
A PVC connector that is female threaded on both ends
A half-inch right-angle PVC connection that is threaded male on one end and non-threaded female on the other
Sufficient length of PVC pipe to reach on a slant to where the barrels are. If need to join two pipes together, you will need straight PVC connector that is female non-threaded on both ends
Two right angle PVC connectors that are female non-threaded on both ends
A piece of PVC to direct the water down to the opening of the barrel
Note: depending on the physical location of the front gutter and of the first barrel, you will need to get creative and make modifications in the parts needed.
http://tylertork.com/diyrainbarrels/construction.html
Rain Barrels - Build your own instructions, Safety, Calculator, and more!
Happy Watering!
congratulations !…
You?
I found your instructable when I was looking for solar panels and rain barrels (coincidentally for my own shed.) I may make a corrugated fiberglass on a frame/overlay to go around my harbor freight solar panels if enough light can go through to be used by the panels. This way, if the fear of the asphalt shingles is sound, I can collect the rainwater from the fiberglass sheets into my barrel while still using the panels!
I also have a composter on the side of my shed along with a watering system for my bees (I have 2 hives going) I call it: ECOSHED!
If there really is a danger, we might as well bag the whole idea of rain barrels for gardens since the vast majority of the roofs in the US are covered with asphalt shingles. That's not true in a lot of other countries where they use tile.
