Redneck Iphone Clip
2,516
36
6
Posted in TechnologyMobile
Introduction: Redneck Iphone Clip
I don't like having my phone in the bottom of my pocket. The QuickDraw effect is also a plus! In this instructable I'll teach ya how to mod a metal phone case with a clip from a normal household item - a tape measure.
Step 1: Case
This will work on both plastic or metal cases. I prefer the brushed stainless.
Step 2: Tape Measure Clip
Grab a Phillips and detach the clip from your handy measuring device.
Step 3: The Clip
Some of the clips protrude out the back a little so you may have to file it flat.
Step 4: Mark It
Lay the clip on the phone wherever you want to mount it and mark it with a marker. I wanted my phone to hang upside down in my pocket so I marked the bottom of the case.
Step 5: Drill It
I used a drill-bit the same size as the rivet.
Step 6: Sand It
Since the case is brushed stainless I was able to follow the grain with a sand sponge to smooth out any burrs from drilling.
Step 7: Double Check
Yup, this looks like where I want it to be and it lines up perfectly
Step 8: Place Rivet
Now just push the rivet through from the inside. (This way there will be a very minimal smooth area against the phone).
Step 9: Add Clip and Washer
Slide the clip over the end of the rivet and go to town! (The hole in my clip is a little larger than the rivet so I found a washer the same size)
Step 10: Pop the Rivet
You can use a handheld rivet gun or a fancy hydraulic one that takes less time. They usually pop it tighter and more secure. (Not pictured here but I grabbed a small nut driver and held it against the washer just to make sure it was seated well).
Step 11: File Down the Rivet (optional)
I used an aluminum rivet which is a little softer to file. Grab a small file and slide it in the spacing of the clip.
This is optional as sometimes the back of the rivet helps it stay in your pocket a little better.
Step 12: Material Over the Rivet
Place a small piece of felt or loop-Velcro over the rivet so that it doesn't scratch your phone.
Step 13: Done!
This literally took about 5mn to do. It cost me nothing but the price of the case. I already had a tape measure laying around and the rivets as well.
Your end result is a low profile, very durable, metal clip mounted to your iphone that doesn't change the structure of the phone itself. It doesn't void the warranty, and it is very simple to do.
    • Space Challenge
      Space Challenge
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    6 Comments
    Brilliant. I definitely see one of these being made in my near future.
    this is not redneck enough try a bottle opener on the top so it covers the apple
    wow, awesome. im gonna make me one.
    Definitely like the idea but my unnatural love affair for JB Weld would not allow me to rivet that clip on.
