Redneck MIDI sustain pedal - DIY
The great secreat of sustain pedals for electronic keyboards is that they are just on-off switches. That is, when you press the pedal, two wires are connected. That's it. Now suppose you are in the mood for composing and playing, and you realize that your pedal is somehow missing. This instructable shows how to make a temporary (but working!) MIDI pedal out of things around you. No tools, experience or ability required !
You will need:
1. An empty CD box
2. 3-5 Paperclips
3. Some wires
4. 1/4" jack/adapter with cable
5. Duck tape
6. Plasticine cat to oversee you activities
Step 1Attach paper clips to make it bouncy
1. Take an empty CD box and remove the label.
2 .Put a bent paper clip inside, as shown.
3. Tape it to the box with duck tape.
Now if you try to close it, it will bounce back, like a pedal. The problem is that it will snap closed if you press hard enough. We resolve this problem in the next step.
34 comments
Nov 17, 2011. 11:15 PMikhan8 says:
brilliant! I made one last night. Works great but I had to make a few changes - mine did the exact opposite i.e. the sustain was on when the paperclips aren't touching - so I just set it up so that when you press down, the connection breaks.
I used and old fashioned tin with a bullfrog clip and it feels very sturdy!
Aug 26, 2011. 7:55 PMelamont says:
thanks for the tip! I cut up an old headphone 3.5 -> 2.5 cord i found lying around, and connected it through a 3.5->jack converter.
works awesomely! now i just need to find a good spring..... ( i dont think those paperclips will last long).....
Jul 15, 2011. 7:58 PMcyphresshill420 says:
Made this and it's the only sustain pedal I've ever needed. I used a spare drum kick pedal instead of a cd case. Told my old radioshack boss about it. He said plastic ones they sell always break and get refunded. He really liked using a metal drum pedal. Thanks Mr. Redneck
Jul 10, 2011. 12:14 AMskantimahanthi says:
Going to try right now ) ......Lets see how it work ....Thanks man !!
Jul 2, 2011. 4:34 PMmunchmucnh says:
I'm a bit confused what kind of wires do i need?
May 21, 2011. 6:59 PMblufalcon94 says:
Thanks so much for this instructable! Works great! The CD case feel weak and like its going to crack any second but its probably just the case that I'm using
Nov 13, 2010. 1:39 PMrkhimura says:
it doesn't works on mine piano, am i doing sometihng wrong, i have a CASIO PX-100
Aug 5, 2010. 1:17 AMall4jesus005 says:
why it never work on my keyboard?
May 2, 2010. 6:40 AMQuest for Questions says:
 Your awesome
Feb 19, 2009. 10:07 AMschnellboot says:
u can change some parts for the very poor person (no I'm not poor): paperclips : alu foil cd case : cardboard and for the ultimate poor persons here u can glue the two contacts on a piece of wood that fits into the female port to use that instead of the mono jack
Oct 13, 2009. 7:39 AMkaradza3a says:
I think if you have money for keyboards, that you won't have any problems with finding paperclips and cd case... :)
Oct 14, 2009. 9:47 AMschnellboot says:
 yeah u r right
Jan 20, 2010. 1:43 AMAgroking says:
 I got mine for free...
Aug 22, 2009. 8:01 AMjournalyst says:
Okay, I don't know why it worked out for the rest of you, because this didn't work for me. I tried several different types of wire and plugs and none of them worked. I guess that's why they call it a redneck pedal...'cause it never works.
Aug 12, 2009. 6:38 PMerljue says:
hey man! nice D-I-Y!! jst would like to ask if it's okay to use other tapes other than Duck tape? thanx
Dec 23, 2008. 5:03 PMBrad09C says:
Hey this worked out great! thanks for the help your awesome.
Jun 29, 2009. 4:02 AMmycal says:
Wow! I didn't believed that it can work, but I was wrong! Thanks man!
May 30, 2009. 10:43 PMTyMan210 says:
I don't really think a redneck would know what a sustain pedal is.
Nov 30, 2008. 11:28 PM-eV- says:
Wow this is fantastic. I just made one and damn, the difference between having and not having a sustain pedal is like night an day! Thanks a lot!
Nov 30, 2008. 9:54 AMmarkthomas says:
hey man ur method is one of the easiest for DIY sustain pedal.... don't even need to leave the house.....lol!!
Jun 23, 2008. 7:35 PMSkellington says:
This is an awesome idea, thanks! Now, I just need to find some paperclips.. If I can't, I'll try a similar concept with staples (and find something else for a hinge that won't close of course). ;D
Jun 23, 2008. 9:29 PMSkellington says:
While searching my house for a CD case not in use, I found an old stapler that was not working. It had a spring and everything, so I used that and now have a stapler sustain pedal.
Jun 24, 2008. 1:14 AMSkellington says:
Hehe, maybe. Once I stop being so lazy and find another broken mic/headphone, I'll do just that. :]
Apr 26, 2008. 8:49 AMdrummonkey92 says:
nice, great idea for the switch...but why "just don't solder" for attaching paperclip to wire? is there an actual reason or is it just that a redneck wouldn't have a solderin iron? lol
Apr 24, 2008. 3:30 PMcodester says:
Wow!!! Great idea! I'm definitely going to make this (my midi pedal wont work on my other midi piano) Great job!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:romwell
