Redneck T-shirt Repair
3,084
13
8
Posted
Introduction: Redneck T-shirt Repair
I had a good sized rip in a favorite work shirt, and figured I ought to patch it. Well, duct tape never did stick too good to wet stuff, so first wash I knew it would be gone. Had some of that 100% Glue to try out, and it's flexible, so what is there to lose?
Oh, by the way, this is my first Instructable, leastways that I can recall, and I took the pictures kinda after the fact, but I fixed that too.
Step 1: Make Yer "duct Tape" Patch
Now everyone knows that duct tape is silver, although there are all kinds of fancy ones out there, but I wanted it to be traditional. Shiny like a chrome ratchet! So I figured I'd go over to the fabric store and browse around to find something silvery and fabricy. What I come across is this stuff they use for ironing board covers and it seems to be about right so I bought a little hunk of it and set about cuttin' it in duct tape width. This little craft cutter made good straight edges. Probably shoulda cut the end with the band saw or run 'em past the belt grinder to rag them up a bit, but didn't.
Step 2: You Need to Make Yerself a Backer Board.
All you need is a stiff piece of plywood that will fit inside the shirt, so the patch don't get stuck to the other side of the shirt. Tape a piece of wax paper on there so the shirt don't stick to the board. Because that would be uncomfortable and make an awful clunk in the washer.
Step 3: Let's Get 'er Done! Glue It to It!
Like I said, I forgot to take the pictures while I was doing stuff and they got took in reverse so there isn't really a picture for this step. Well, there was another little hole under the arm, so I'll fix that too and now there's a picture.
Went and cut the ends of this little patch with the scroll saw and let it flap about a bit. looks like it was ripped off the roll, as it should.
Now, if you're like me, you will get this on your hands. See that tape on the bottle at the top right? Well it took some searching but I found what gets it off. Acetone, alcohol (don't waste good 'shine, but if you kept the heads when you made it, use them) or naptha (lighter fluid). Really, that info should be right on the bottle. In big letters!
So, line it up good and slap it on.
just a side note, my buddy what makes the Rebel Rum Reserve out in the next county tells me that the heads with all them higher volatiles really sets the wood stove alight quick! So if you're making shine don't pour the first bit down the sink. It's useful for cleaning and fire starter, but just make sure you label it poison so it don't get drunk, cause that bit is what can make you blind or at least gives you wicked hangovers. Don't taste good either.
Step 4: You Gonna Finish That Sandwich?
Put another piece of wax paper on top, then a couple layers of rag to get an even push on it. Drop the top board on and, be careful, clamp it all together.
Mind you, like I said, you want to do this careful like so you don't get the patch sliding out of place or make wrinkles.
Now you can leave it for a good hour or so.
Step 5: Well, It's About Time, I Reckon.
So if you're skittering about doing other stuff, like making another high tech drinking jar, set a timer for an hour and if it reads 00:00 when you notice it, then it's probably fine to undo the clamps and see how it looks. Peel back slowly in case there is a bit of glue sticking to the paper. It peeled off nice for me.
This glue takes about a full day to get to its full strength, but you can handle it gently now.
Hope the shiny stuff don't wreck in the washer. I'll let you know if I think of it.
Step 6: There, I Fixed It!
...and now you know why the patch is silver.
Keep your stick on the ice!
  • Paper Contest 2018
    Paper Contest 2018
  • Sew Warm Contest 2018
  • Gluten Free Challenge
8 Comments
Backer board? Like chawin' tuh-backer?
Nice shirt.
Well, only if the chaw stains blend in with the ones already there, otherwise, a piece of plywood or MDF would probably be about right ;p
This is a great way to patch a shirt and it's very well documented, thanks for posting it! How does the glue hold up to washing?
For followup, Danger is my middle name, I washed the t-shirt in warm water on permanent press cycle (had dress shirts to wash too), and dried on perma press, then another dryer run with the jeans normal and it held up just fine. I normally wash on warm or cold, so I'll have it on a normal warm wash next time.
I am having difficulty getting the 100% Glue to come out of an oogoo chain maille mold, so if you use the 100% Glue in Oogoo, it might be a good idea to use a parting compound like Mann's spray to be safe. It's just the spots where I cleaned and didn't reapply the Ease Release 200. Doesn't relate directly to this project, but useful info nonetheless.
I don't know yet. I just did this today. I'll try to wear and wash it next week. I want to know how it feels too. I'll cold water wash it inside out to minimize wear on the grey/silver coating.
