Reducing Friction
Introduction: Reducing Friction
The following information is a single lesson in a larger Tinkercad project. Check out this and more projects on Tinkercad.
Return to Previous Lesson: Filleting - Taking the Edge Off
Lesson Overview:
Now we're going to learn how to reduce friction on your puck!
Step 1: Introduction
Now that we have a puck with a nice, rounded edge, how else can we increase the performance of the puck?
We may be able to increase the performance of the puck by reducing the surface area that connects with the ice.
How can we do that without making the puck smaller or changing the shape?
We can break up the surface!
In this lesson, we will use Tinkercad's Smart Duplication feature to carve patterns in the surface of the puck so less of the puck will contact the ice.
n the next lesson you will learn to [description of next lesson, derived from title]
  1. Continue to the next step.
Step 2: Pasting or Importing Shapes
If you are continuing this puck lesson directly after the previous filleting lesson, then you were instructed to 'Copy' your object, so Tinkercad will remember it.
Try pasting, now. If your filleted puck emerges, you are ready to continue to the next step.
If Tinkercad did NOT paste your filleted puck, that's OK, because we also downloaded your puck for 3D printing in the Filleting lesson.
  1. Go to the Edit menu and click on Paste.
  2. If your puck from the last lesson does not appear, import the STL file you saved.
  3. Find the 'Import' section in the Shapes menu on the right of your screen.
  4. Click on the 'File' button, and then the 'Choose File' button. Navigate to where your browser saves its downloads. Your object file should be there.
  5. Once you have selected your file, click the import button. Your object should appear and it will behave like any other Tinkercad shape.
  6. Continue to the next step.
Step 3: Preparing Circular V-Groove
I think a good first experiment would be to cut concentric rings in to the surface of the puck.
Concentric means "circles or shapes which share the same center". This is a relationship between items like "Tangent" we explored in the last lesson. Again, these are only words to help talk about your design.
We are going to construct a complex shape in this step to carve these rings.
  1. Drag out two cones and one cylinder and turn the cylinder and one of the cones in to holes.
  2. Rotate the cone shaped hole 180° about the Y axis and lower it until its point is 17mm below the Workplane, along the Z axis.
  3. Raise the cylinder 3mm off of the workplane and then use the Align tool to center all three of these objects together along the X and Y axes, only.
  4. Continue to the next step.
Step 4: Positioning the V-Groove With the Top of Puck
We're going to use this new V-shaped ring to apply V-shaped grooves to the top of our puck.
  1. Rotate the V-Shaped ring 180° about the Y Axis and lift it 24.5mm off of the workplane.
  2. Use the Align tool to center the ring to the puck along the X and Y axes, only.
  3. Continue to the next step.
Step 5: Duplicating and Scaling the V-Groove
Now that the first V-Groove Ring is in place, let's make the second.
  1. Duplicate the ring.
  2. While holding Shift and Alt, scale the duplicate to 22mm, thus growing it 10%.
Step 6: Smart Duplication
Ready for some magic?
Go to the Edit menu and selected Duplicate again... and again... and again... until you have 14 rings, total.
Each ring will grow in size by 10%.
What is happening?
This is 'Smart Duplicate'. This feature will watch what changes you've made to an object after it was duplicated. Then, by making a duplicate of the duplicate, Tinkercad will apply the same changes to the next duplicate!
  1. Duplicate your duplicate of the original ring.
  2. Continue to duplicate the ring until you have 14, total.
  3. Select only the rings and then align them so that they share the same lower limit.
  4. Turn these rings into holes.
  5. Continue to the next step.
Step 7: Group
Select all the objects and group them.
You should now have your first experimental puck with considerably less contact area than the original!
  1. Group your rings and your puck together.
  2. Continue to the next step.
Step 8: Duplicating and Reusing Shapes
Surface area may not be the only characteristic that could have an effect on performance. Maybe orientation of the circles will have an effect, too.
For instance, would the concentric rings reduce or increase spin? What would happen if we cut the grooves across the face of the puck?
While we are at it, why don't we try altering the pattern a bit for another experiment?
  1. Duplicate your puck so you have a copy of your current design.
  2. Ungroup one of the copies and delete all but the largest of its Rings.
Step 9: Offsetting the V-Groove
Now, let's take this ring and offset it so it is no longer concentric with the puck.
  1. Move your ring 37.5mm in the positive direction along the X axis.
  2. Duplicate your ring and move the duplicate 75mm in the negative direction along the X axis.
  3. Group these ring.
Step 10: Duplicating With Rotation
Duplicate this new group and rotate it by 22.5°
Once you've rotated the shape 22.5°, duplicate the shape again... and again... and again. Duplicate it until you've gone full circle around the center of your puck. You should have 16 rings in total.
  1. Duplicate the group of rings and rotate the duplicate 22.5°.
  2. Duplicate the duplicate of the rings.
  3. Continue to do this until you have 16 copies of the original ring.
Step 11: Group Your Final Shape
Select your puck and your rings and group them.
Now we have two very different surfaces that may have different influences on the behavior of the puck.
  1. Select your Puck and your Rings and group them
Step 12: Congratulations!
Now, here's where the fun begins!
What original surface ideas can you come up with?
Using the steps we've tried in this lesson, can you create a pattern on the edge of the puck?
How else can you alter the shape and texture of the puck using Smart Duplication?
How will these surface patterns affect the pucks performance on the ice?
In the next lesson you will learn to customize your puck!
Next Lesson:Personalizing Your Puck
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
