Refashioning Flea Market Finds - Rusted Metal to Modern White
3,643
67
11
Published
Introduction: Refashioning Flea Market Finds - Rusted Metal to Modern White
About: Bioengineer by degree, web designer by career, crafter by passion.
This DIY project is so simple, but gets really nice results!
I recently went "garage saling" with my mom, and we stumbled upon an antique store that was closing. The owner was dying to get rid of her merchandise, and I basically died of excitement. Thrifting and vintage shopping is my favorite hobby. I love everything about it. The more piles of junk, the more hidden treasures there are to find. My mom and I ended up with a lot of vintage silver-plated kitchen accessories, some of it beyond repair. These pieces were begging to be refurbished in some way. Most of them had that ornate, floral decoration around the edges of the dish. It's very typical of the silver plated decor that you see in thrift stores these days, and a little dated if it can't be polished up.
Step 1: Clean & Scrub
This, although obvious, is a very important step!
I am admittedly a lazy person and I like to take short cuts, so I sympathize with you guys out there who want to skip this step. However, if the piece you are refurbishing is not free of dust, dirt or oil, it will ruin your project. The paint will not properly adhere to the metal.
So, specifically, use soap and water, along with a hardy scrub brush or sponge. Make sure to clean in the grooves of the design if there are any nooks and crannies. Sometimes I use a Q Tip with rubbing alcohol.
You don't have to be worried about maintaining the finish of whatever you are cleaning because it will soon be covered by paint. I would recommend doing some research before cleaning metal with any products if you are not eventually going to use something for this project.
Step 2: Spray Paint Coating
Pure white decor is very trendy these days. Textured glass, plastic, or metal looks modern and brand new once the flaws and patchy discoloration is hidden.
For this step, find a flat, even surface to work on in a ventilated area.
I once made the mistake of doing this project on top of newspaper in the grass. The paint coating turned out uneven and patchy. I even ended up with the imprint of blades of grass in the paint. Not good.
Grab some newspaper, or plastic table cloth you don't mind ruining.
I usually do multiple pieces at once to save resources. Lay out the objects so that you have vantage points to every angle that you'd like to paint (except the part laying on the surface).
After you have covered your flat surface, you are ready to begin painting.
A word on the type of paint...
The type of spray paint you use is not necessarily important. If you use a paint specifically for metals, then it is extremely easy. If not, I would recommend using a metal prep solution, sold in Home Depot or other hardware stores. The paint may chip if you don't use the correct materials.
If you are painting glass, the paint won't last forever regardless of what you use. For wood, any spray paint will do.
Follow the directions on the can of paint you have in particular. They are all pretty similar, but just in case!
Hold the can at least a foot away from your objects. If you have worked with spray paint on 3D objects before, you know that it is pretty easy to end up with dripping paint if you don't make sure to do this. Spray evenly in a methodical manner, spraying in a side to side motion or in a sort of swirl.
The first coat of paint will not necessarily cover the metal completely. It may just look like a dusting of paint at first, but that is exactly what you want to start with. This will dry quickly
Repeat this about 3 or 4 times, waiting to make sure the previous layer of paint is dry before you begin the next. Girls, think of painting your nails. It takes forever for your nails to dry completely if you don't wait in-between coats.
Step 3: The Endless Possibilities
Spray painting is so easy and so versatile. I have redone furniture, used stencils with fabric, created custom wood signs...
Virtually any material will (temporarily) hold spray paint. Have fun with it!
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    11 Comments
    Wow, that really looks great. Another cool technique you could use on something like this, is quickly painting it black with some slightly watered down paint, and then wiping the black paint off with a rag immediately. The black will stay inside the nooks and crannies giving it a great weathered effect and making the details really pop.
    Do you have a picture of something like that? I'd love to see what the final product looks like
    I don't know if the technique has a specific name, but I know that Adam Savage uses it. I did find a video of him demonstrating it, sorry it's a bit long. He uses it here to weather a new box he built to make it look older and used.
    http://www.youtube.com/watch?v=YXzxEqdvuIE
    Chalk board painting these is a new trend in Maine. They come out really nice.
    Ooh that would be so cute for a rustic wedding or classroom
    Spray painting is a great way to turn something old, into something new and shiny again. We did it with an old "Power Wheel" car we thrifted, and it went from sun-faded to awesome looking in a couple of hours. Having done some industrial painting, I can attest that 75% of a good paint job is simply in the prep. Clean it well as you said, and use a primer made for your material; plastic, metal, wood etc. My best recommendation for spray paint is Valspar brand, available at Lowes, but not Home Depot. It is by far the best rattle can paint I've ever used. Something in the smell of the chemicals itself smell much more like a heavy industrial paint, and less like the cheaper stuff.
    I will have to check out Valspar and compare it to what I have used in the past. Thank you for the recommendation!
    This is a fabulous idea! Thank you!
