Step 7Do the refill process
#1 Plug the refill adapter on the big tank FIRST
#2 Screw the little thank on the adapter.
#3 Flip the tank over like on the picture.
#4 Open the valve. The instruction say to let in open for 1 minute but you will hear the flow of propane stop after 30-40 seconds. When the sound of the flow stop, close the valve.
#5 Flip over again the big tank and remove the little one of the adapter. Some propane will escape from the adapter during this process.
Repeat the operation until you have filled all of your tanks.
The valve may have been used to bleed air on the first factory fill.
But as you use the original fill, propane gas exits only. No air enters the tank.
The "air" in the tank is simply leftover Propane gas at a pressure of approx 1 atmosphere.
To vent this gas is wasteful and you run the risk of overfilling the cylinder too.
What happens then? As the temperature rises the pressure valve releases the extra, wasting more gas.
