Step 9Check for leaks and store refilled cylinders
I store my refilled cylinders outside just for precautions, in case of a leak.
I also put a protective cap like on the picture to protect the threads of the boottle.
Good luck refilling.
#1 Do not, under any circumstances, a cylinder to 100 %! Propane has a high temperature/volume expansion rate. Too full when cold means it pops off when it goes hydrstatic (liquid full @ high pressure). 85% MAXIMUM!!!
#2 propane expands at a ratio of 1 to 270 when it goes from a liquid to vapor. Stack up 270 of those little cylinders in your trunk behind where your kids ride in the car on a good hot day.
#3 There is a technical explanation as to why you find half full 1# cylinders in the forest, I mean besides the fact they are wasteful litterbug jerks.
It goes like this, If you know the physical properties of propane, you know that propane appliances burn propane vapor. At atmospheric pressure propane is a vapor. At -44 degrees it is a "0" pressure liquid. Pressurize propane in a tank and you can keep it liquid at higher temperatures. Think thermodynamics. Small tanks, small volume, gas cools in cylinder faster, chills gas to -44, no vapor, no burn. No burn, must be out of gas, throw away 1/2 full tank. (yes, I've seen it! Over and over!)
Big tank, big volume,gas cools slower, doesn't get to -44, burn hotter longer
Better yet, just don't do it. state an federal agencies do'nt write rules to "big Brother" us. They may seem misguided sometimes but they really want us tobe safe
#1&2
Gasses expand with temperature.
If Nit-wit fills a tank's total volume with liquid gas under pressure, there's no room for it to expand.
Tank bursts.
Ouchy.
#3
As Nit-wit uses the gas in the cylinder quickly, more liquid evaporates cooling the rest of the liquid because of the same physics air conditioners work on.
The rest of the liquid gets so cold that it won't evaporate any more.
Nit-wit discards half full cylinder.
Half full tank has time to warm up again.
Smart guy picks up half full cylinder.
Litter Bad.
Free Propane Good.
This is a dangerous thing to do. There is a good reason that these cylinders are not rated for refilling. They are designed for 1 use, but are over spec'd for safety. It's that safety margin that you are playing with.
Have you ever seen the sort of explosion and the devastation that one of these can cause, it can easily kill.
So if you’re going to refill, then having more info is very valuable. It could save your life. So if you do not understand the info passed on here, do not refill any cylinders. Or, rather do, and rid the gene pool of yourself.
Jaykaying, Johnsned51, jkjk...
I actually learned something. Thank you.
follow the rules and play it safe and go easy and you'll be alright
the only reason i wont do this is because i'm pretty lazy
I work on an AT maintenance that can have as many as 20 people in a group (though usually around 10), and we use one of those temporary tarp "garages" as our kitchen. We set solid folding tables down the middle and have propane lanterns on the top of the "tree" and Coleman propane stoves set on the tables, all hooked to a couple of 20# tanks. Then our folding chairs go along the sides of the tent. It gives us a centralized, protected, and comfortable area to prepare and eat our meals and socalize.
Using the 20# tanks directly means we don't have to deal with the hassle of refilling 1# tanks. A 20# tank can run a propane lantern and a couple of Coleman stoves for quite some time.
Both of these effects mean you probably want to limit the number of times you refill a given cylinder, and use some fragmentation shielding (e.g., lexan plate) during the refill process.
http://www.heatershop.com/mr_heater_portable_buddy_20lb_kit.html
Why bother to use the small tanks at all?
If you were hiking 5 miles to a backwoods campsite, would you want to strap a 30# tank to your back or pack a couple of the small canisters?
