3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
CatGenie: Refilling A SaniSolution Cartridge
This Instructable will demonstrate the easiest way (that I've found) to refill a CatGenie ("CG" henceforth) SaniSolution Cartridge ("cartridge") with a minimum of time and mess.
Note:
This Instructable does not cover how to RESET a cartridge. This only covers a method to refill an empty one. Admittedly, that makes this Instructable useless by itself, but resetting the chip on a SaniSolution Cartridge is covered in my other Instructable.
Step 1Disclaimer, Materials and Safety
DISCLAIMER
I am not affiliated or endorsed by CatGenie or PetNovations LTD in any way. CatGenie is a registered trademark of PetNovations LTD.
SAFETY
You will be choosing your own solution to refill the cartridge with, so take all necessary precautions. I recommend gloves and safety glasses if you're the least bit uncertain about getting it in your eye or on your skin. I am using Simple Green", which is fairly inoccuous, but I would still recommend the safety glasses.
Beats losing an eye, right?
MATERIALS
The materials list is very basic:
- An empty CatGenie SaniSolution Cartridge (duh)
- Two cups of the solution of your choice to refill it with (double duh)
- A measuring cup of at least 2 cup (500ml) capacity
- A pair of needle-nosed pliers, hemostats, or some similar grabbing implement
- A small bit of wire, plastic or whatever to use as a spacer (trust me)
- A small kitchen funnel
- A straw; a McStraw if possible
41 comments
1-40 of 41next »
Nov 8, 2008. 10:19 PMadmin says:
This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work. Thanks!
Nov 28, 2010. 9:30 AMJim Wolfe says:
Any one trying D-128 for replacement liquid in their cartridges.?
Mar 24, 2010. 6:15 PMmamalang says:
 I'm having a problem with my Genie dispensing all the liquid in the refilled cartridge during the first few washes.  Anyone have this problem and come up with a solution?
Dec 18, 2008. 2:58 PMb4cans says:
(removed by author or community request)
Dec 28, 2008. 10:40 AMkfouryou says:
have you figured out the dilution?what is the name of the solution your going to use and do you know where it is available
Dec 29, 2008. 2:47 PMcmb24 says:
I measured about 2 gallons of water per wash - 3 washes per clean or 6 gallons (boy thats a lot of water, a toilet only uses 1.6 gal/flush!).
If a sani-cart lasts 60 cleanings; assuming it adds solution for each of the 3 washes???, thats 6 gal x 60 cleanings = 1 sani-cart for 360 gallons of water. 15Oz./360gal = 0.0417 Oz/gal. That requires some heavy duty concentrate! The strongest stuff I've seen calls for dilution of 0.5 Oz per gallon (OdoKleen, from CalVet.com & others). CG dispenses 1/10th of that! Simple Green recommends 2 Oz/gal for a "light wash", so CG would be 1/40th of that. So the question remains, will a substitute be too weak to be effective?
Dec 29, 2008. 4:18 PMgks says:
I have a feeling that the solution is only dispensed in the last of the 3 wash cycles. That's when you can smell the scent of the solution. So that would make the dilution approximately 1/2 oz per 2 gals of water. I have some of the following on order to test out, should be very similar to the original formula, there are 3 strengths available: http://www.buckeyeinternational.com/products/disinfectants/sanicare/index.html
Dec 30, 2008. 6:14 AMcmb24 says:
Yes I thinks its safe to assume solution IS dispensed in the last wash (the drying heat makes it noticeable). The first 2 washes I'm not positive. Even if it is only the one time: the dilution is 60 uses x 2 gal/use = 120 gal & 15Oz/120gal = 0.125 or 1/8 Oz/gal (or 1/4 Oz per 2 gal). Still kind of weak, but perhaps good enough...? Let me know how how the formula you ordered works!
Dec 30, 2008. 7:28 AMgks says:
Sorry, I meant 1/4 not 1/2! And yes I'll let you know how it works out. I'm mainly looking for something that won't leave the granules sticky and does not have an offensive odor to me and my cats. So if you go with the Quat-256, it has a recommended dilution of 1/2 per gallon. That would make it one forth the recommended strength. Also it only comes in rose scent at that strength. I suspect CG is using something even weaker then this to save costs. Just MHO.
Jan 3, 2010. 5:31 PMmonsoon60 says:
This seems like a good place to ask, anyone try the Swiffer "Wetjet" solution? It is $4.00 a liter and available everywhere.
Jan 16, 2009. 6:12 PMgks says:
One of the litterbox-central members did an extensive logging of the CG operation and discovered more then 1/2 of the total dose of solution is dispensed on the wet granules during drying cycle!!!
Jan 2, 2010. 8:32 PMmonsoon60 says:
Does it matter if you reset before you refill? I can't imagine it would but I thought I run it past the masters ;-)
Dec 16, 2009. 4:13 PMpeebody says:
I found that a turkey baster with the bulb removed from the end works really good for refilling the cartridge. It fits snugly into the cartridge opening, and fills it very easily if you DO NOT inflate the foil bag first. The weight of the liquid will expand the bag as you fill, thus eliminating the need to let air escape with the piece of wire. If there is a little liquid still in the tube after filling, a slight squeeze on the sides of the cartridge will cause a "burp" and the rest will go right in.
Nov 7, 2008. 12:48 PMcrapflinger says:
have you figured out something besides simple green yet? i love the smell of the stuff...but i know for a fact my cat hates it..
Dec 29, 2008. 3:02 PMcmb24 says:
Scott - Is the simple green effective? From my calculations, it will be extremely diluted (@ 0.04 Oz per gallon), about 1/40th of the SG recommendation for a "light" wash (assuming my calc's are correct). Could it be simply, that the water is doing most if the work? Makes me wonder if the solution does much at all...
Dec 29, 2008. 7:34 PMkfouryou says:
So has anyone come up with a winner for a substitute for the simple green? I Read on here about someone having trouble with their boards led staying on ? I have the same prob and no luck with my reset working I'm wondering does it matter if the power is coming from the usb or the battery.
Feb 4, 2009. 8:41 AMgks says:
I started a thread on the subject of replacement solutions over here. Lot's of good info! Find out what others are using and how it's working.
http://www.litterbox-central.com/litter-box/catgenie/topic2747.html
I also sell a reset device here:
http://www.smartcartridgereset.com/
Jan 17, 2009. 2:21 PMgenie_refiller says:
I live in Montreal, many products mentioned in the posts cannot be found here.
I just ordered this product from my vet:
http://www.vetoquinol.ca --> find product --> clinicide
recommended dilution is 1:128 I plan to test it pure and diluted in half. cost 80$ / gal
Jan 3, 2009. 11:23 PMglate says:
What is everyone else using to refill with? I just filled with this product, I will report back on how it goes.
http://www.naturecleanliving.com/all_purpose_cleaning_lotion
Jan 13, 2009. 10:33 AMgenie_refiller says:
did you put the product as is? or did you dissolve with water?
Jan 13, 2009. 11:10 AMglate says:
As is. So far it works fine, zero odor but the sides of the bowl are a tad sticky.. I never paid attention to it before and have nothing to compare it to though. When this batch runs out I'll try another cleaner and see how it goes. For the time being I've hooked up a dummy/empty cartridge once a week and ran the catgenie with no soap in it just to make sure all residue is gone.
Jan 5, 2009. 6:16 PMacapobia says:
I was considering using odo-ban since it appears to be a strong disinfectant and not very potent on perfume. I think Wal-Mart carries it.
Jan 13, 2009. 10:32 AMgenie_refiller says:
Just wondering. 2 tablespoons of javel in the two cups of water... does that make sense? Should I add something else in the recipe?
Jan 2, 2009. 12:30 PMkfouryou says:
yes I agree about the solution is in the last wash I noticed just before the dryer starts, it dispenses a small amount around the brim and thats where the fragrance comes from maybe it sanitizes it I don't know ?
Dec 29, 2008. 2:44 PMcmb24 says:
Has anybody measured the volume of water the CG uses for each wash of a clean cycle (I think it does 3 washes per cycle)? If we are refilling the cartridge with concentrate we should get the dilution correct... I figured I can calculate the amount of solution used for each wash as 15 Oz / 180 (60 cycles x 3 washes) (assumes solution is used at each wash. Can measure the water from the discharge hose into a bucket (a clean wash...). Was wondering if anybody did this already. I am thinking of using the sani solution available from Vet supply stores. (disinfects, cleans & deodorizes and are pet safe).
Dec 23, 2008. 12:56 PMkfouryou says:
have you tried any other solution? I heard simple green isn't good for ammonia
Dec 17, 2008. 7:25 AMgks says:
I'm the guy selling the Smart Cartridge Reset device. I want everyone to know the negative post TheMadViking found on Yahoo Answers was a hoax my competition is perpetrating in an attempt to discredit me. I still have the best reset device on the market and my customers are all satisfied. My device is full featured, fully warrantied with a money back guarantee. Check it out for yourself http://www.SmartCartridgeReset.com
Dec 9, 2008. 10:02 AMnokamoto says:
Thank you for posting this instructable, Scott. Now I can get to work on all my empties!
Nov 23, 2008. 9:39 AMjeff waldie says:
Has anyone come up with a replacement for the granules? Would uncooked long grain brown rice work? any ideas?
Nov 7, 2008. 8:17 PMBamZipPow says:
You could probably even use a turkey baster to fill it with as well. :D
Nov 8, 2008. 6:49 PMjongscx says:
...could you just connect a tube from the top plug to an external reservoir and avoid the whole mess of having to refill the mini cartridge altogether?
Nov 9, 2008. 8:29 AMBamZipPow says:
No...it has a counter on the cartridge. You would have to still reset that every 60 counts.
Nov 7, 2008. 4:09 PMmcreynol says:
Excellent write ups. Great sense of humor too!
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:ScottSEA
