3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Reflective Bracelets
  • last photo ←
I was at the home improvement store when I stumbled upon these reflective strips. True, you can buy already made reflective bracelets but this gives you a little creative freedom.
The pack came with 4, 1”x6” strips; 2 red, 2 white for about $3.00.
To make them start by removing the adhesive backing to two strips. Spray the sticky side of the strips with window cleaner. Sandwich the two together, sticky side in, and line up the edges. Use a credit card to squeegee out any air bubbles and excess fluid.
Next roll it up. How tight you roll the bracelet in this step will determine how tight the bracelet ends up. I placed it through a roll of electrical tape. Then I rolled up some card stock and ran it through to help set the shape. Place the assembly outside to dry; about an hour on a warm day.
When dry, remove the bracelet from the circular forms. Since the inner diameter is smaller then the outer you’ll end up with a little over lap on the edges of the bracelet. Trim this off. You can leave it as is or move on to cutting.
For a little more style bust out your wife’s crafting scissors. These type of scissors are used in scrap booking and come in all kinds of patterns. I used a pattern called “Colonial”. Run the scissors along both edges and your done.
12 comments
Jun 6, 2011. 3:31 PMsuayres says:
Do they lose shape as time goes by? Because it occurs to me that you could beef up their structural integrity by building them around, say, an aluminum armature.
May 31, 2011. 5:56 AMPACW says:
Brilliant! Excellent descriptives; one could probably understand clearly even without the photos. . . or follow the photos without words I suppose. I happen to have a package of these I purchased and then didn't use and forgot to return. Very excited to try this. Thank you!
May 29, 2011. 11:00 PMfarzadbayan says:
I love the Carbon-Connections, that looks like Nano.
May 29, 2011. 3:35 PMrlm98253 says:
Would it not be simpler to use the pattern shears before you roll up the reflective material?
May 29, 2011. 2:29 PMdcollier1 says:
Nicely done!
May 29, 2011. 8:48 AMbgeorge98121 says:
I'm going to add this to my cycling reflective wear.
Thanks!
May 28, 2011. 11:24 AMlyonpridej says:
This is something my teenagers would like to do & my grandkids would love!
I've never heard of using the window cleaner like this, I would have thought it would mess up the adhesive. I'm assuming that instead, it just slows the adhesive from sticking until the cleaner dries/evaporates? Interesting the things you learn!
May 27, 2011. 11:44 PMlionmartyn333 says:
Sir
bracelet is Nice
May 27, 2011. 7:30 PMpoofrabbit says:
I always get so excited when you post something new! Another great easy to do project, well done!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
963
Author:Mrballeng(Visit my shop)
I've opened up shop =). Click "Vist my shop" to check it out. Or write me at info@mrballeng.com
