Refracting Light With LASERs
Introduction: Refracting Light With LASERs
LASERs make almost anything better, and that includes refracting light in physics lessons.  Here's a guide to refracting LASER light, and some calculations you might need to do afterwards.
Step 1: Just a Bit on Theory
As a beam of light enters an optically more dense medium it slows down.  If a beam of light is traveling diagonally, some parts will slow down before others. This causes the light ray to bend towards the normal (the normal is a line drawn perpendicular to the surface where the beam of light hits).  The opposite happens when a light ray leave a more dense medium.
Step 2: Equipment
Your will need:
  - A laser (and plug if necessary)
  - A protractor
  - A ruler
  - A calculator
  - A pencil
  - A perspex block
  - A peice of paper
and, most importantly:
  - A really cool sticker!
Step 3: Draw Around the Perspex Block
Place the block on the paper and draw all the way around it with the pencil.  This rectangle (unless you have a differently shaped perspex block) will serve as a guide to show you where the block was when it is removed for measuring the angles.
Step 4: Turn the LASER On
This is probably my favourite step:
Plug in and turn on the LASER!
Step 5: Start Refracting!
Place the perspex block and paper in the path of the laser, making sure that the block is still aligned with the rectangle you drew.  It should look something like the picture.
Step 6: Marking Out the LASER's Path
When trying to draw out the line formed by the LASER, you can't simply trace it with your pencil, because that wouldn't be a properly straight line so it would be difficult to measure the angles for calculations, and placing a ruler down would break the laser beam and you wouldn't know where it is.
To mark out the beam, you take your pencil (make sure it is sharpened) and mark one dot at one end of the line, one near the middle, and one at the other end of the line.  Do this for the beams either side of the block, being careful that you don't move it.
Step 7: Drawing the LASER Beam
Turn off and tidy away the LASER.
On either side of the block, join up the dots, to make the line (by the way the reason we drew three dots instead of two, when you only need two dots to make a line, is that the third one can act as a check to see if the other two make sense, e.g. if all three don't line up, its best if you start again).
Then we join the points where the lines meet the edge of the rectangles, and this shows where the LASER beam was as it traveled through the block.
Image three shows how it should look after you have completed this step.
Step 8: Draw the "normal" Line
Use a ruler to draw a dashed line, called the normal line, at 90 degrees to the block's surface.
Step 9: Draw and Measure the Angles
Draw the angles i and r like they are in the picture - between the light ray and the "normal" line.
Measure this with a protractor, and note this down.
I got  i = 41 degrees and  r = 25 degrees
Step 10: Finding the Refractive Index of Perspex
The formula for finding the refractive index (usually called n) is:
        sin  i
n = --------
        sin  r
plugging in the values we got for i and r we get
n = 1.55 (2dp)
Step 11: Other Versions of the Formula
Of course, in an exam you might not always get told to find n, but instead be given i , n and asked to find r, so it is useful to have seen other versions of the formula:
i = arcsin( n x sin( r ) )
r = arcsin( sin( i ) / n )
(arcsin is the inverse sin function, or sin to the -1 on your calculator)
Good Luck!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    cool! this reminds me of a demo I saw at the smithsonian that was showing how different types of telescopes work. kind of like this.
    YES! Lasers make math more fun. Cool project. Hope you can find a camera that allows you to take better photos in the dimness required for laser-visibility.
    Yeah, I know about the camera, all the pictures were actually taken at school for a guide we're supposed to make (this is it). Unfortunately, i don't have a LASER.
