I recently purchased a Lincoln AC-225 welder for $40 (Minus leads of course). Before I plugged it in I decided to take it apart and clean it. I will show you how you can take your old welder and make it work like a new one.
These machines have been produced for many years, and chances are you own one, why not pass it on to your kids?
I cannot state how easy this is to accomplish. Chances are if you own one of these welders you are more than proficient to dissemble its simple switch assembly and properly clean and lubricate it. In fact, the most difficult part in my opinion, is the tedium of removing the screws to access the internals.
Please, do not be afraid to attempt this.
You will need:
Tools to remove sheet metal screws, plus a phillips, and flat screwdrivers
5/16", 3/8", an 7/16" box end wrenches and sockets (One of each for each size)
Good quality grease. I used Mobile-1 Synthetic automotive grease
A Dremel tool with light abrasive polishing bit
Remove these ads by
Signing UpStep 1Cut the breaker, unplug the welder, then start removing screws.
So make sure your tombstone welder is unplugged, because it's too early to have your own. Tombstone, that is.
There are lots of screws. Mine had an amalgamation of flathead, phillips, and hex-head screws. I am not sure if they come from the factory like this.
I did not take pictures of every step as far as screw removal goes. All I can tell you is to keep all of the screws in a container.
The front specification plate must be removed. To do this, there are 4 screws in the front, but you must also remove the selection switch handle (White arrow). To do this, simply remove the flathead screw that is in the fat portion of it. (See green arrow)
10
comments
Add Comment
rimar2000
says:
Add Comment
