Step 3Cut and install the liner fabric
My liner came out so well I was able to use the original liner as the pattern for my new liner. If needed, you can take paper and lay it in the case to fashion a pattern.
Be generous with this part. It beats buying more fabric and cutting it twice.
My liner took less than a yard to create.
I used spray adhesive to adhere the liner to the case. Make sure to cover up parts you don't want to get sticky with newspaper (see photo). Read the instructions on the spray adhesive to make sure you apply it for a permanent hold.
Spray the majority of the surface. You can always come back and spray small areas along the walls. After spraying, quickly lay the liner piece in place, being sure to smooth out any wrinkles. Recover the trim with newspaper and spot spray any areas that need it.
Next, trim off any excess liner so that it fits snugly tucked under the trim.
Take the hot glue gun and glue the liner to the case UNDER the TRIM.
Next, hot glue the trim to the liner.
Repeat this process for the other side and you're almost done!
Add Comment
