3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Refurbish a rusted crowbar
How to refurbish a old and rusted crowbar.
Got some old rusted (partly) iron tools from a friend or your grandparents? These these are usually of higher quality and strength then the basic tools from a local shop. So don't be to quick to put the tools in the trash bin.
Using a steel brush and a file (the workshop tool to treat wood and metal) you can restore the the tools to former glory.
Photo 1: The beginning
Photo 2: The end result
Step 1Tools and fixation
Tools and fixation
It is very time intensive to use a hand steel brush, therefore I use a steel brush that can be mounted in an electric drill.
Find yourself a drill with a high rpm, and don't use  a cordless drill since you will be switching batteries every 5 minutes.
Be sure to use a proper clamp to securely fixate the rusted tool! You are using a steel brush at high speed and don't want to shoot into your clothing or other surrounding objects because the rusted tool was not secure enough.
If possible, use a drill with a second handle, this helps positioning and reduces the risk of damaging your own hands.
10 comments
Feb 6, 2012. 9:10 PMstrmrnnr says:
Thanks for the tip on the heat treatment also.
Feb 6, 2012. 9:08 PMstrmrnnr says:
Let us know how long it takes for the bar to rust again if it does.
It was a good instructable - but I know that if you just wire brush rust (at least thick rust) all you are doing is knocking off the outer layer and polishing the firmer rust underneath. On the ships (steel) we use pneumatic chipping guns to remove the rust and get down to the bare steel.
This instructable is another really good one for restoring old tools if you haven't seem it yet.
www.instructables.com/id/Electrolytic-Rust-Removal-aka-Magic/
Feb 4, 2012. 3:45 PMshantinath1000 says:
Naval jelly is also good for removing surface rust. It is basically petroleum jelly with an acid mixed in. Wipe it on , let it sit for a while and wipe it off.
Feb 4, 2012. 6:27 AMstrmrnnr says:
Will this remove all traces of DNA also?
Feb 4, 2012. 8:32 AMTheBlackSharpie says:
Gordon Freeman would have loved this!
Feb 1, 2012. 8:22 AMrimar2000 says:
Also you can use liquid PHOSPHATIZANT, it is very good for convert and prevent rust.
Feb 1, 2012. 3:08 PMrimar2000 says:
Maybe this product is from USA.
Feb 1, 2012. 2:58 PMrimar2000 says:
I live in Argentina, my data wil not serve to you.
The base of phosphatizant is phosphoric acid (same of Coke!) but I don't know the concentration. It does not hurt the skin, makes a grey coat over the rusted iron. You can see it here or in others mine instructables.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:j.g.kuster
I'm a student in Mechanical Engineering at the Twente University, the Netherlands. In my spare time I love to design and build all kinds of construction project.
