Refurbished Dresser
Published
Introduction: Refurbished Dresser
About: I begun in that artistic/craftsman world by the hand of my mother who is potter and art teacher. Also in my father's hobby wood-workshop I learn to lathe and use all kind of tools. I coursed some studies ...
Hello everybody,
It's a long time I don't post anything, and time to do it again has come. B-)
I had a (really ugly) dresser only suitable to be thrown away. But before to throw it, I ask to myself: -STOP! Can I refurbish/tune it up? -And, of course, the answer was: -YES!
As usual on my projects, to do this you need a really low budget. For less than 4€ I give to this horrible TV furniture a bunch more years of life!
Let's see what I do with this.
Material used:
1 old ugly drawer (required and mandatory) - Already own
3 different gift wrap paper rolls (can be more or less, and of course, you can use fabric, plastic of whatever material you prefer...) - 0,60€ each.
1 roll of gift wrap transparent plastic.- 0,75€
4 plastic guards (bumpers) - Already own
White glue, foam painting roller, brush, stapler, scissors, screwdriver, cutter and cutting mat. - Already own all these tools and materials.
Step 1: Preparing
Before begin to tune it up, I needed to clean it up well.
First, to clean well the drawers I'llI take off the remaining pullers using the screwdriver.
I Clean all drawer's surfaces with 96ºAlcohol. As I need to glue paper on it, I can't clean these furniture with furniture cleansing products because they are made containing wax and other products to gave shine and polish to the furniture and this also prevent the glue to stick on the threatened surfaces.
I seize the opportunity to add some reinforcements on the edges to give to the dresser more stability.
Step 2: Cutting
The easiest step on this project is this one. It consist on take the cutter, scissors, ruler and a cutting mat and... CUT! Cut a lot of different sizes paper pieces. I Cut some squared and some other with rectangular shape.
Step 3: Glueing
To glue the paper pieces I found that the best way is to dilute some white carpenter glue in some water and with this and a painting ruler, paint/glue the surface where we want to stick the paper.
First I begin with the structure glueing a lot of little pieces on top.
For the laterals, I glue a big paper piece on each and over it I go glueing little pieces of the others decorated papers.
On the edges, apply the glue with a pencil, and stick the paper trying to do it without wrinkles.
For the drawers, I think it could look better maintaining some parts of the original white colour, without any paper on it. To do that, I glue the front part of the drawers like I do before, with the ruler, and go sticking pieces of paper giving some space between them. Doing like this gives the front part of the furniture a less "baroque style".
After glue one side (laterals, top or the drawers) to prevent wrinkles I found about is a good idea brush it up again with a dry painting ruler. To do this is good do not press the ruler too much, because only  is needed to hide a little bit the wrinkles, and if you press too much, you can break the paper...
Step 4: Finishing
To protect the surface I place on the top side a transparent wrapping plastic piece attached with staples,.
To make the pullers, using the old holes on the drawers for the pullers, I insert on one of this holes a string locked in one side by a button. After doing this I stack some coloured beads and lock, for the inside part of the drawer, the string with another button. To fix this string, a made a knot and with the flame of a lighter burn it to fix it.
On the down side of the lateral pieces, I nail some plastic guards to separate the paper from the floor, because if I do not this, when cleaning the floor, we can damage the paper...
And... that's it! And now go to enjoy (and use) this new dresser!
Step 5: Last Touch
With this colourful tv furniture, I fount the tv is too  boring (no only the programs, the tv itself) and I decided to tune it up as well.
I go for my old citedell paint on the box where they are stored for nearly 15 or 20 years and I select the more shining and purpurin locking ones.
Drop some paint on a platter and with a new trim roller, go painting the tv plastic parts trying to paint it un-mixing the colours.
Once dry, add some white and red squares and hang the tv on the wall and that's it.
A new look for the horrible dresser / tv furniture.
Hope you like it (and hope you understant my bad English writing...  but... Yes I know...  :D )
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
