Remodeling a kitchen is no easy task, but every time I see a home show where someone says something along the lines of "and our remodel only cost about $40,000" I have to laugh to myself. I bought my house right out of college as a foreclose for just a little over 60k. The house was built in 1901. It needed a lot of work and given the modest salary of a full time graduate student, everything had to be done under a very tight budget. I had no prior construction experience before I purchased the house. I was fortunate enough to have an Uncle in the area who had been through some similar things to get me rolling, but it was largely thanks to internet resources such as this site that I was able to acquire the knowledge I needed to get the job done.
The kitchen renovations took place in two main phases. Phase 1 was when I first moved in and the goal was to get things "livable." Phase 2 came a year and a half later when it was time to do things right. Phase 1 cost probably in the neighborhood of $500 (including appliances) while Phase 2 ran about $900, bringing the total cost to a paltry $1,400.
If you want to checkout any of my other projects visit the blog I've kept on the renovation at
http://mrbippers.blogspot.comAlso please vote for me in the Burning Questions 7 contest if you like this Instructable.
This is the only picture I had of the original kitchen and it really doesn't do the awful state of things justice. There were three levels of ceilings (ancient plaster, then collapsing cardboard type tile, and finally office type ceiling tile). Not only was the ceiling in bad shape, but the layers lowered it about a foot and a half. I've 6'8" so I needed to reclaim any height I could. The tiles on the wall were plastic tiles with about a half inch of glue. The 220V kitchen receptacle didn't work. There was a single, loosely attached ceiling fan with no switch. You needed to open and close a door to enter the kitchen from either of the two entrances. Etc, etc... Long story short, it needed work.
Improving your home is always a rewarding endeavor, & having it done right the first time is priceless.
Thanks so much; I'm redoing my counters this weekend and had already informed myself on most of the details and had came to the same conclusion on 24" vs 26". However your idea of using wood trim for the edges is genius and something I had not considered!
Thank you so much since I agree this works fine and looks great. And is MUCH MUCH easier than dealing with cutting all those extra tiles!
Depending on the accents you could even try wrapping the wood in thin sheets of copper or stainless steel. There was an instructable where printing offset sheets obtained free from local printing presses were used to make an aluminum desk, so that may be an option.
If you do go with bullnose you would add the bullnosed edge to the vertical tiles. Unless you can find a bullnose of identical granite, you would either have to cut the 12" tiles into thinner strips and try to edge them yourself or have some place do it for you. It may also be an option to find a bullnose in another style tile that picks up some of the colors from the granite and acts as an accent. Keep in mind the height of the tile and just make sure you have enough clearance to still open any drawers. Good luck!
(and I love your Tetris tiles :D)
Also, remember if you like this instructable to rate it using the stars in the top right corner. If you don't like it, well you can skip that part =).
