RC Car Controlled by Arduino Sensors - Autonomous and Easy to Construct
Published
Introduction: RC Car Controlled by Arduino Sensors - Autonomous and Easy to Construct
This instructable shows how to re-build a second hand remote control car. You will see how to re-wire the circuit board. As well, basic coding and Arduino based skills are demonstrated in this construction. The final product should be able to navigate its way through any environment it is placed in. This will be done by using small sensors.
Step 1: Learning About the Circuit Board
The first step you need to do is learn about the circuit board and understand its components. This was done by pulling our cars apart.
My car comprises of:
6V battery requirements
Different areas on the circuit board which control numerous things
Step 2: Learn the Basics of Arduino
During class we were taught the basics steps needed to use an Arduino these are below.
You can download the Arduino Zip file from: http://arduino.cc/en/Main/Software
Arduino Lesson
First expand the zip file.This will give you the Arduino application. (You can run this from anywhere)
Next go to tools, serial port and select - /dev/tty.usbmodem1411
Click open and go down to basics, then load the control blink
You now Verify the code and then click Upload.
That is the Introduction to an Arduino.
Step 3: Jumper Leads and Ports
In this stage you will take apart some of the circuit board. To do this you use a solder remover. You should be able to remove the IC from my circuit board, enabling yourself to control different motions of the car manually. To do this you will need to make jumper leads. These leads connect power to the circuit board on desired ports. These ports were then tested to determine which ports control the cars ability to turn left or right and move forwards and backwards.
Step 4: Connecting the Jumper Leads to the Ports
Now you solder the jumper leads to the circuit board in the correct ports which control the movement of the car. After this you then solder together the pin stack to the other end of the jumper leads. This allows the Arduino to be plugged into the circuit board of the car
Step 5: Directional Movement and Control
Now you need to determine which pins control which directional movement. You do this by testing each pin, with a wire connected to the battery. After you have figured out which pins do what, display this by using some tape and writing it on that. After this connect a wire to the earth pin. This then allows you to upload the code to your Arduino.
Step 6: Figure Eight Movement
Now that the car has directional movement, you can now test codes instructing the movement of your car. Below is the code for a figure eight movement and a video showing a test run.
This code came from https://www.instructables.com/id/Autonomous-Control-of-RC-Car-Using-Arduino/
Car Test Makes the modified RC car go in a figure 8.
Plug the striped white wires into the Arduino pins as
int forward = 12; // forward pin
int reverse = 11; // reverse pin
int left = 10; // left pin
int right = 9; // right pin
// The setup() method runs once, when the sketch starts
void setup() {
// initialize the digital pins as an outputs:
pinMode(forward, OUTPUT);
pinMode(reverse, OUTPUT);
pinMode(left, OUTPUT);
pinMode(right, OUTPUT);
void go_forward()
digitalWrite(forward,HIGH); // turn forward motor on
digitalWrite(reverse,LOW); // turn revers motor off
void go_reverse()
digitalWrite(reverse,HIGH); // turn reverse motor on
digitalWrite(forward,LOW); // turn forward motor off
void stop_car()
digitalWrite(reverse,LOW); // turn reverse motor off
digitalWrite(left,LOW);
digitalWrite(right,LOW);
void go_left()
digitalWrite(left,HIGH); // turn left motor on
digitalWrite(right,LOW); // turn right motor off
void go_right()
digitalWrite(right,HIGH); // turn right motor on
digitalWrite(left,LOW); // tune left motor off
// the loop() method runs over and over again,
// as long as the Arduino has power
void loop()
go_forward();
delay(1000);
go_right();
delay(3000);
go_forward();
delay(1000);
go_left();
delay(3000);
go_forward();
delay(1000);
go_right();
delay(3000);
Step 7: Learning About Sensors
To enable the car to interact in any environment it will need sensors. The sensor I chose was the SRF 05 Arduino Sensor. This sensor has the ability to sense objects up to 2-3000cm away. Below is how to set up the sensor with the Arduino.
1.Download the source
2. Place the DistanceSRF04 folder in your Arduino1.0+ "libraries" folder
3. Open example sketch: "file", "Examples", "DistanceSRF04", "Centimeter" (or "Inch" or "Time")
4. Connect echoPin to pin 2, trigPin to pin 3 (and connect Vcc and GND)
5. Compile & upload code
6. Sensor data should be arriving over the serial port
Here is a photo of my setup:
The source is available below.
Step 8: PWM
Pulse Width Modulation is an important aspect of programming cars. This allows for you to manually control the amount of power given to certain motor, or more simply control the speed of the car. It changes the code from digital to analog.
Below is the sample code to input pulse width modulation:
analogWrite(forward, 100);
This allows you to change the amount of power between 1-255. The number in bold is one that can be
Step 9: Using Two Sensors Instead of One
After some basic tests it was seen that the car, at certain angles, couldn't sense objects in front of it. To solve this problem, I have used two sensors, angled on the front of the car. This gives a wider view for the sensors to detect any objects. To do this, the second sensor needed to be added into the code. Below is how this is done:
All you need to do is connect the second sensor into the same GND and VCC pins, but add a second lot of pins for Echo and Trig.
I have used pins 5 and 6 for the additional Echo and Trig ports for the second sensor.
Step 10: The Final Code
The final step to completing the car, is combining the movement code, with the code for the sensors.
You need to ensure you recognise all variables in the void set up, to ensure the codes will work.
My final code is shown below:
In this code I have instructed the car to reverse and turn right, if it gets to close to an object. If there are no objects it will continue to go forward.
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    6 Comments
    Is it possible to use only one sensor then we will use a servo motor to sweep the sensor at different angles? And how? Thanks!
    Looks really good, a really detailed intructable. Hope i can see a video soon. I have a few issues coding and need help with paulse modulation maybe you could help me
    I'd love to see a video of this thing in action. Looks really cool!
    Yeah sure, a video will be uploaded soon.
    Thank you. I'd like to see this in action aswell.
