Step 2The basic idea
For this project we will be using the Simerec SIS-7C chip which allows up to 7 different logic outputs (of which we will only be using 6) in order to control our relays that will in turn switch on/off power to our sockets. The SIS-7C cannot run on wall current so we will also need to add an internal power supply for the small electronics. The current output from each of the SIS's output pins is sufficient to drive each of our 5V relays so there is no need for any other intermediate switches! YAY less soldering! The SIS-7C also allows a mode for logic switching so there is no need for extra logic flip-flops! YAY again!
Here is a concept design which I sketched out in chalk before starting. It uses output 7 from the SIS-7C to control one socket via a remote. I'm pretty sure the pin-outs are correct but always triple check each connection with the appropriate datasheet before turning on the juice!
comment
Add Comment
Add Comment
