3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remote Control Power Strip
Step 4Prepping the sockets and little tips from safety Bob...
Each wall outlet has two sockets that are normally connected to the same inputs. But most are equipped with easy to remove connectors, turning each outlet into two independent sockets to be controlled by different buttons on our remote. Each of our relays is rated for 3A, which is plenty for most single socket lights or appliances. If you plan on keeping each socket on the same circuit (i.e. two sockets or per relay), plan accordingly by getting bigger relays and using a larger gauge hookup wire. Always remember to never draw more than 15A through anything, ever.
Safety Bob says...
Wall currents are VERY dangerous. You may die if you ever come in contact with a live socket so always take the greatest care around live wires. Don't touch anything if it's "hot." Always unplug anything before handling it. Another tip I got from my electrician is never touch anything with two hands. If you are electrocuted while touching something with two hands, the current is much more likely to involve one arm, your heart, and your other arm. Getting electrocuted through one finger will hurt, a lot, and you will probably need to go to the hospital... but I know I'd rather take a trip in an ambulance than a hearse.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:jwad650
