Remote Control Power Wheels ATV Safe for Kids Under $150 !!!
3,497
53
4
Posted in TechnologyRemote-control
Introduction: Remote Control Power Wheels ATV Safe for Kids Under $150 !!!
This instructable will show you how to make a safe Remote control Power Wheels for kids UNDER $150.
Parts:List :
Power Wheels ATV $99
Remote control $25
steering servo $5
Speed Control $12
steering linkage $3
Battery plug $4
Things you will need :
Screwdriver
Drill and bits
Solder iron
Dremel Tool
Step 1: The Electronics and Power Wheels ATV
You will need
Remote and receiver 27mhz 2.4 ghz or what ever you want. Im using a 27mhz Traxxas TQ3 controller and 3 channel 27mhz receiver.
Electronic speed control This is a basic electronic speed control.
Steering Servo This is a standard 1/10 steering servo. You can use larger 1/8 servo for better steering.
Power Wheels ATV You can find all types of power wheels online to try this with.
Step 2: Open the Power Wheel Up
you will want to splice into the battery with tamiya connector
Step 3: Add Servo and Speed Control
you will need to add the steering servo in the front.
Add receiver and speed controller.
Step 4: Add Wires From Motor to Speed Controller
connect all wires to speed controller and receiver.
you will use the stock battery.
close it up and your done.
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    • Make it Move Contest
    4 Comments
    Some time ago I bought a electric car for my grandson which already had a remote control implemented. The only drawback was that it didn't have a real speed controller but only run/stop/reverse buttons and for steering move to left/right buttons.
    I always thought about implementing a smoother speed control (also for the gas pedal in the car) and a steering system that works like the one for rc-cars.
    The biggest problem in my opinion is to find a low-cost servo or actuator for the steering since you need a relatively high torque to control the wheels.
    You suggest a "standard 1/10 steering servo" - is this one really strong enough to do that job? I'm missing the part of the instructions which show how you mounted the servo to the steering wheel/bar and how it works when the driver want's to take over control. How did you solve the concurrency problem?
    Thanks for the post.. looks like fun
