3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remote Controlled Basket Ball Robot - HARLEM GLOBETROTTERS -
Here I will show you how to build a remote controlled basketball robot. That's right, no joke! I have built a similar ball for the HARLEM GLOBETROTTERS and now you can build your own.
Here's a list of supplies you'll need.
Petsmart:
7" Hamster Ball
Sports Shop:
Basketball
www.servocity.com:
High Torque Metal Gear Servo. I used the HS-645MG
Aluminum Servo Shaft Horn 250HS
(3) Aluminum Hubs 3463H
RZ12-90-128RPM Gear Motor
Servo Mounts
Gear Motor Mount
(2) 1/8 ID Bearings
1/ 4 ID Bearing
Any Hobby Shop:
2 channel radio and receiver set (More channels are fine)
Gyro
(8) Elite 1500 batteries
Cheap ESC (Electronic Speed Control)
Hardware Store:
3/ 4" Aluminum Flat Stock
3/ 4" Steel Flat Stock
Misc Nuts and Bolts
Double Stick Tape
Lead weights (Or steel)
Great Stuff Expanding Foam
Step 1Sketch / Plans for the Ball
Here are rough drawn plans for the ball. It has a Gyro for stability control, a servo for steering and a gear drive motor for propulsion. This ball moves only because the weight at the bottom moves. So, the idea is to get as much weight as far below the centerline as possible. Led or steel weights are added to help.
119 comments
1-40 of 119next »
Sep 19, 2011. 9:36 PMdoshh says:
Are those geared motors u mentioned for the ball brushed or brushless? tnx ^^
Aug 1, 2011. 8:11 AMimran_bhoot says:
what does Gyro basically mean? Would you please lighten ma ignorance? :-/
Apr 11, 2010. 7:00 PMeulaliaaaa! says:
It would be easier just to put a toy truck in the hamster ball and drive that around...
May 15, 2011. 7:55 AMdombeef says:
What happens if it flips over?
May 19, 2011. 7:22 PMeulaliaaaa! says:
True.
May 20, 2011. 3:55 AMdombeef says:
Unless you put wheels also on the top, then it might work
May 20, 2011. 2:13 PMeulaliaaaa! says:
Or you could get one of those cars with huge wheels that can do flips on walls and stuff.
Feb 14, 2011. 5:56 PMmightywombat says:
About how much could I expect a project like this to cost? Not counting the multi-channel transmitter, I suppose, since that would drive the cost up considerably.
Sep 25, 2009. 11:08 AMtoxicwolf says:
I used your concept and made a tennis ball size version
Feb 14, 2011. 5:51 PMmightywombat says:
I'm really curious to see your remote controlled tennis ball! I've been thinking that an RC soccer ball or something similar would be a great toy for my dog, but a tennis ball that I can bring back to myself if she decides she doesn't want to fetch it? That's effing brilliant!
Feb 1, 2011. 9:48 AMTobor 2.0 says:
O my god I've been trying to do the same thing. How ever did you get it so small ( the robot i mean) you have to post an indestructible on it
Sep 25, 2009. 11:10 AMtoxicwolf says:
with built in camera
Sep 28, 2009. 1:11 PMtoxicwolf says:
sorry but I don't have any pics and I sold it but ill make another and do an Instructable on it but it might take a while before I can make it though
Jan 27, 2010. 3:05 PMVulcanator says:
i wanna see this.
Feb 1, 2010. 11:22 AMtoxicwolf says:
5 weeks away from finishing just got to find the right type of board to control it
May 21, 2010. 8:29 PMdombeef says:
It is longer that 5 weeks.
And this looks very cool!
May 21, 2010. 9:35 PMtoxicwolf says:
dude i totaly forgot been so busy with school and other projects i try to finish         i havent check this account in a long time
Nov 9, 2010. 11:25 AMJamesRPatrick says:
Bogus.
Nov 9, 2010. 3:46 PMtoxicwolf says:
ive officially given up every time i worked on it something went wrong ;something went wrong my nephew broke it twice and my camera was at my friends when his house burned down
Feb 1, 2011. 9:50 AMTobor 2.0 says:
Dang talk about bad luck.
Feb 1, 2011. 4:09 PMdombeef says:
I think he is lying...
Nov 25, 2010. 11:29 PMthelastonekills says:
sorry, this is going to be stupid, but
could this be applied to a much larger sphere 2.5 m diameter
and what size motor would you need and how much would the counter weight have to weigh to get a good speed (min 20 kmh 30-40 kmh good)
and is there a formular for calculating the speed.
it would in theory need circumfrance, counter weight mass and lenght of the arm,
and motor strength i think?
Oct 4, 2010. 2:59 PMTobor 2.0 says:
try making it small enough to fit in a tennis ball and post the instructions. if you already have and i missed it pleas say so.
Feb 24, 2010. 12:42 PMgradof6b says:
When this spins is the whole internal thing, like the weight and stuff that's spinning or are they stationary as the ball spins?
Aug 31, 2010. 4:31 PMhintss says:
stationary, weights move the ball because they're always down
Jul 18, 2010. 9:23 PMDehLeprechaun says:
how much did it cost to make this?
Apr 11, 2010. 6:20 PMMACKattacksnipe says:
were you fill up air did you put some kind of rechargeable power socket
Mar 25, 2010. 12:07 AMElvenChild says:
 If I put this inside a soccer ball I could cheat I mean coach easier
Feb 7, 2010. 4:35 PMshadowyblade says:
 More details on how it is made, please!  These instructions seemed somewhat vague.
Aug 31, 2009. 5:50 PMplatinum97 says:
Hey I love ur idea. This would freak my friends and my parents out but I'm not that advanced and I don't have most of those things, so can iu help me make a simpler version of this just by using a dc motor and a smaller ball to put it in?
Feb 28, 2009. 1:45 PMbocaj812 says:
If this were an actual robot built using a micro-controller you could program the steering arm to be electronically forced to go back and stay in the center of the ball when not in steering action. I love the instrucwble though. I plan on building one myself.
Aug 29, 2009. 6:47 AMben moody says:
Actually thats not true i myself am building this robot from scratch using a micro controller for a school project. on this guys robot the arm has centered itself. the gyro is used to dampen the rocking motion not to centre the arm.
Feb 5, 2009. 10:27 PMnecropolian says:
very supercalifragilisticexpialidociously cool! can you play basketball with it whitout destroying the inner technologies? 5*
Feb 6, 2009. 11:16 PMnecropolian says:
and if it could bounce without 'pushing up the daisies' it still would be useless because you can't control it when it touches the ground only fractions of a second. and on bumpy grounds it would be a pyrrhic victory if you were able to bounce it into a specific spot...
Jun 23, 2009. 11:08 PMbsamuels453 says:
it doesn't need to be on the ground in order to change the ball's trajectory, just wobbling the steering chassis back and forth would create a noticeably strange effect
Jun 26, 2009. 12:17 AMnecropolian says:
but still, it is much less controllable in midflight. the steering has more effect on solid ground. but it is still very cool.
1-40 of 119next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:prabbit22m
I would love to find a job where I could play with fabrication tools all day and be creative. Anyone have a suggestion?
