Here's a list of supplies you'll need.
Petsmart:
7" Hamster Ball
Sports Shop:
Basketball
www.servocity.com:
High Torque Metal Gear Servo. I used the HS-645MG
Aluminum Servo Shaft Horn 250HS
(3) Aluminum Hubs 3463H
RZ12-90-128RPM Gear Motor
Servo Mounts
Gear Motor Mount
(2) 1/8 ID Bearings
1/ 4 ID Bearing
Any Hobby Shop:
2 channel radio and receiver set (More channels are fine)
Gyro
(8) Elite 1500 batteries
Cheap ESC (Electronic Speed Control)
Hardware Store:
3/ 4" Aluminum Flat Stock
3/ 4" Steel Flat Stock
Misc Nuts and Bolts
Double Stick Tape
Lead weights (Or steel)
Great Stuff Expanding Foam
Remove these ads by
Signing UpStep 1Sketch / Plans for the Ball
And this looks very cool!
could this be applied to a much larger sphere 2.5 m diameter
and what size motor would you need and how much would the counter weight have to weigh to get a good speed (min 20 kmh 30-40 kmh good)
and is there a formular for calculating the speed.
it would in theory need circumfrance, counter weight mass and lenght of the arm,
and motor strength i think?
