3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remote Controlled Pan and Tilt Head
I always wanted a remote controlled pan and tilt head. Maybe it was for my video camera, a rubber band shooter or a water gun aimer. It doesn't really matter what you put on the top deck (as long as it's not too heavy), with this little project you'll be able to aim it. You don't really need any special tools and it shouldn't cost more than $65 (Canadian).
Step 1Stuff you need
Stuff you need
  • C:\Documents and Settings\arden\Desktop\Instruct\DSC03559.JPG
  • C:\Documents and Settings\arden\Desktop\Instruct\DSC03564.JPG
  • C:\Documents and Settings\arden\Desktop\Instruct\DSC03560.JPG
  • C:\Documents and Settings\arden\Desktop\Instruct\DSC03591.JPG
Here are the parts you need:
4 x 1/4 Nylon washers
1 x 8-32 x 1/4 Chicago screw set (it is a 2 part set that screws into itself see pic) (Poulin #222-269)
1 x 3" Swivel or lazy susan flat ball bearing. (In the cabinet hardware aisle at Home Depot)
1 x 28ga 8" x 10" Sheet metal block end (used for blocking cold air returns)
1 x Hitec HS-322HD servo motor (general purpose type), you can use other servo motors, but be careful; some, (like Futaba), go in the opposite direction (Pan motor)
1 x Hitec HS-755MG servo motor (heavy duty 1/4 scale with metal gears and ball bearings) (Tilt Motor)
1 x Hammond 1411N enclosure or deep octagonal electrical box with cover or deep square electrical box with cover
12 x 4-40 x 1/4" machine screws
8 x 4-40 x 3/4" machine screws
2 x 4-40 x 1/2" machine screws
24 x 4-40 nuts
1 x 4-40 washer
1 x 1/2" Rubber grommet
1 x 1/4-20 x 1/2" machine screw (optional camera mount)
1 x 1/4-20 nut (optional camera mount)
Locktite
A servo controller of some type. There are many kits available (google "electronic kits" or try www.bpesolutions.com). A DMX controller is available at http://home.att.net/~northlightsystems/. An RF style controller is available at most hobby shops (like one for a car or airplane - needs 2 servo outputs), there are a few on this site and I will post mine when it is working and not jittery. It may be advantageous to have the controller before you start the project so that you can test your movements as you go.
Tools:
Aviation Snips or Tin snips
Square
Ruler
Drill press (or a drill and a really steady hand)
Drill bits - 13/64", 1/2", 27/64", 7/64", 3/32"
4-40 metal Tap - Optional (see text near end of step 6)
Optional but a great way to make really round holes is with a step bit and a 1/4" bit
A bench vice or a sheet metal bender (called a metal brake)
Hammer
Staedtler Lumocolor fine point marker (fantastic marker with a slim body) or Fine point Sharpie marker
Single hole punch (three hole will work too)
26 comments
Aug 28, 2011. 2:53 AMMaalk says:
Hey im kinda a potato cannon enthusiast and i was thinking how awesome this would be to hook a cannon up to one of these. after looking at the video attached, i saw that the rotation and tilt are far too fast for what is required. Any suggestions on changes to your design that would slow down the movement and perhaps provide more torque?
thanks for your time and consideration
Apr 30, 2011. 4:25 PMCheatGuy28 says:
Can you somehow connect this to a camera jib/crane. And if you can how? Thanks. BTW love the design!!!
Apr 30, 2011. 10:51 PMCheatGuy28 says:
Im making a metl based jib which is also remote cotrolled. I thought it would make a good aditive.Plans for the jib im making can be found here:
Mar 8, 2010. 9:48 AMyannmoritz says:
Hey, very nice work!
I'm interested: how much weight is possible to put on this construction?
Mar 8, 2010. 6:20 PMyannmoritz says:
i would try to put a 6kg light on it.
would this work?
Mar 11, 2010. 1:44 AMyannmoritz says:
Anyway, thank you very much. Gave me lots of ideas!
Feb 2, 2010. 1:10 AMdompower says:
Hi Guys!
I am looking for metal fixure clamps to connect servo motors together to construct my own humanoid robo.
Any suggestion from where I can get these fixtures?
thank you.
Dominic Ancelm
Saudi Arabia
dompower@gmail.com
Dec 6, 2009. 12:24 AMevilme says:
Hi, from the hardware and items you have described, it sounds like you are some sort of theatre lighting tech, convinently , so am i, with the dmx, is it like using a pc recordable desk , but trading the lights to motor? I was thinking of using midi to controll somthing simmilar.
Regards, Jack
Aug 4, 2009. 7:42 AM17hmr243 says:
im liking it heaps. but u lost me at buy the servo and then what? how do i tune it in to remote from rc car? is there more i need to no how and where do i learn servo adapting ? all i whant in simple talk is what u made running. car rc to move it.
Jul 21, 2009. 10:20 PMexerp says:
I like it.. Will be building myself one very soon
Jul 1, 2007. 7:08 PMcurve12 says:
Very cool. Can't wait to see your controller when it's done. What did you use as a controller for the video?
Apr 17, 2009. 7:00 AMThomasR142 says:
what about this?
http://www.vellemanusa.com/us/enu/product/view/?id=522065
or maybe this?
http://www.vellemanusa.com/us/enu/product/view/?id=522038
mind you I'm not shore what the difference is between them?
hope that helped... a bit
Aug 10, 2008. 1:44 PMCRVerdusco says:
Any one interested in having DMX controlled stepper motors or Servos should look at this link. I found this awhile ago, the circuits are based off of a common DMX transceiver and then from there have different output controllers.
http://www.hoelscher-hi.de/hendrik/english/stepper.htm
Jan 28, 2008. 12:54 PMjimwig says:
first post - howdy all you pack rats and inventing/reverse engineering types try to build/change moving head lights tiller's pan and tilt is very much part of the mechanism. since i must do a little different effect i must use steppers. anyone got any knowledge this area? thanks sir--- may i have another may i have another
Sep 16, 2007. 11:03 AMmrgalleta says:
Very nice! I'll try to make one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Tiller
