3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remote Detonator
Remote Detonator
here is a guide on how to make your own remote detonator (using radio):
you will need, a brain, two hands, eyes and some stuff below
a soldering iron.
solder
wire snippers
wire strippers
and pliers.
Step 1Parts (transmitter)
Parts (transmitter)
ok, here are the parts.
Transmitter:
Case: I used a case from Rapid, I can't remember what the code was, but it comes with buttons and the project fits perfectly into it. Or if you are using it as a detonator you might want to make a snazzy case with lots of switches and knobs to make you feels more powerful.
Electrical Components:
i am from england and i use other companies to all you americans. i dont know if Digikey stock them or Radioshack, or you can use the internet. (dont complain to me though, its your problem)
two resistors, 1M resistor (R1) and a 150R to 400R(R2) are the values (you can get them anywhere in the world) the letter then number in the brackets for all the components relate to the layout and schematic (if you cant find these on radioshack then well...)
two capacitors:
(c1) Ceramic disk. value; 100nF
(c2) Electrolytic. value; 100uF (you should be able to find these on radioshack as well)
I.C.s
(U1) HT6014 this it the encoder chip, i dont know if you can get it over in america, but it works well and it is very available in U.K.
(U2) AM-RT4-418 this is the radio module, again i dont know if you can get it in america, tough cookies if you cant.
LEDs
(D1) this is a 5mm led of any colour you want the resistor value to be between 150R and 400R beware that 150R will have the Brightest LED but any lower the LED will burn out.
Miscellaneous:
3V battery holder (two AAAs) you can get that in america
SW1 - SW4 these are the transmitter switches (you guessed it, it is four channel, which means that you can detonate four different things seperately. the rapid order code for these is 78-0622. see they are PCB pushes.
18 pin dil socket you can get these in america. this is to mount the chip in.
then finally (for the Transmitter at least!)
an eight pin dil switch, this is optional and is purely to encode the signal, you need the same code on both ends to be able to use this. (might come in useful so no one detonates the stuff when you are close!)
That concludes the Transmitter parts list...
96 comments
1-40 of 96next »
May 25, 2012. 12:28 PMmonsterman says:
where can you get the radio modules from?
Jan 3, 2011. 9:01 PMjoeyhof says:
what kinda power supply can i use
Nov 28, 2011. 11:32 AMrbaluyut says:
i can't see the electrical output for the receiver witch where you can put the nicrome wire.
please show me i want to make one..
Jan 29, 2011. 6:56 PMjoeyhof says:
ok did you desinge this from your head or did you find how to build it on a website because im having such a hard time trying to build this thing?
Apr 21, 2010. 10:08 PMSev the Sniper says:
Hi, does anyone know where to buy the encoders and decoders from? I have checked rapid and various other shops but with no luck.
Thanks
Jan 9, 2011. 7:13 PMjoeyhof says:
solarbotics.com for the encoder and decoder
Jan 7, 2011. 11:21 AMjoeyhof says:
were do you attatch the wires on the reciever to make it ignite? can i use a premade circuit board?
Mar 9, 2010. 2:54 PMuxaxi says:
are there any transmiters that you can buy in america that will do the same thing as yours?
Feb 12, 2010. 11:16 AMdd_dodd says:
You don't specify which relay to use, any specific part # I should look for?
Nov 1, 2009. 3:14 PMlunchboxslayer27 says:
where did you get the pcb?
Dec 12, 2009. 5:56 PMbombmaker2 says:
i'm not 100% on this but it looks like he etched it himself
Dec 13, 2009. 9:05 AMbombmaker2 says:
that's wat i thought
Oct 13, 2009. 11:56 AMjb.clarke says:
 Why is there 5 relays yet there is only 4 channels/switches
Oct 13, 2009. 1:05 PMjb.clarke says:
so when you press any switch is triggers both the top relay (from pin VT) and the one for the chosen channel?
Nov 14, 2009. 5:00 AMsamlewis2406 says:
 will the led connected to the 4 channels still light without the relay being there?
Oct 20, 2010. 8:59 PMjb.clarke says:
 Which CAD software did you use?
Oct 9, 2009. 4:22 AMtulavatalo says:
will this work with a 9v or a 12vbattery
Aug 30, 2009. 2:47 PMsamlewis2406 says:
im having trouble locating a HT6014 can you please send me a link of where to find this chip i have been searching for quite a while now
Jul 11, 2009. 1:56 PMbombmaker2 says:
how big were the boards u used
Jul 11, 2009. 2:23 PMbombmaker2 says:
also how did u make the layout
Aug 28, 2009. 5:21 PMbombmaker2 says:
yea i dont hav any of that
Aug 26, 2009. 4:08 PMKWeippert says:
Hey...You do realize that the two pics for the parts list for trans. and res. are the same pic. Just thought I would point that out. Please update this. Thanks
Apr 5, 2009. 8:00 AMfatboy106 says:
rapid do everything
Jul 18, 2009. 11:55 AMlifelong-newbie says:
Do they do the required encoder, decoder and radio equipment? They're what i can't find
Aug 4, 2009. 6:09 AMyedead1 says:
if rapid don't sell them maplin probably will
Jul 17, 2009. 12:10 PMlifelong-newbie says:
Hi, great ible I'm UK based too, who did you use for parts? Regards Tom
Jun 18, 2009. 11:35 PMlaverack69 says:
hi, would it be possible to make it work just one device rather then 4, and would you still need the ic chip? Thanks
Mar 31, 2009. 4:24 AMmrwabbit says:
Sorry I'm newbie here. So where on the receiver circuit does detonation occurs? and where do i stick the nichrome wire? Thanks.
1-40 of 96next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:collard41
