Remote Kill Switch
Published
Introduction: Remote Kill Switch
About: My name is Jason Poel Smith I am a Community Manager here at Instructables. In my free time, I am an Inventor, Maker, Hacker, Tinker, and all around Mad Genius
There are a lot of times when it is useful to be able remotely turn something on or off. In this instance, my son has a small Power Wheels car. I wanted to be able to remotely turn the car off if he drives too far away or in the wrong direction. So I designed a simple remote kill switch. This lets me turn the car (or anything else) on and off with a remote. As an extra safety feature, if the car goes outside the range of the remote, it will automatically turn off.
Step 1: Watch the Video
Here is a video walkthrough of the project
Step 2: Materials
Here are the materials and tools that you will need for this project.
Materials:
Radio transmitter and receiver (such as a pair of walkie talkies)
Automotive Relay
741 OP AMP integrated circuit
100 microfarad capacitor
1 kohm resistor
10 kohm resistor
3.3 kohm resistor
2 x 1 amp Diodes
Small sliding switch
Jumper wires
Circuit Board
Heat shrink tubing
Glue
Quick Disconnect connectors
Tools:
Wire Strippers
Screw Driver
Soldering Iron
Knife
Step 3: Select a Radio Transmitter and Receiver
The first thing that you need to do is find a suitable radio transmitter and receiver. You can use an RC car, an old pair of walkie talkies, a wireless doorbell, or anything that you have lying around. The only requirement is that it needs to be able to send and receive a constant signal. For example, a walkie talkie will continuously transmit a signal as long as you are holding down the send button.
For the best results, try to find a transmitter and receiver that has a long range and doesn't pick up a lot of interference.
In this example, I am using a pair of spy gear walkie talkies.
Step 4: Modify the Receiver
In most cases your receiver will need to be modified a little bit.
You need connect to the output of the receiver. In this case, I am using a walkie talkie and the output is connected to a speaker. The output signal is a series of pulses that are sent to the positive terminal of the speaker. The negative terminal of the speaker is connected to the ground of the receiver. We need to connect to both of these wires. So I cut the wires going to the speaker. Then I stripped the insulation off of the ends.
I also cut off the call button from the receiver because it wouldn't be used.
Step 5: The Control Circuit
The control circuit that I designed for this project uses a 741 OP AMP to monitor the output of the receiver. Two series resistors (3.3kohm and 1kohm) form a voltage divider which sets a reference voltage that the OP AMP uses for comparison. These resistors may need to be changed to calibrate for your receiver. When the output voltage of the receiver goes above this reference voltage, the output of the OP AMP goes HIGH and activates the relay.
I am using an automotive relay so that it will be able to switch high currents (up to 40 amps). However larger relays like this also require more current to activate. The OP AMP can not output enough current to activate the relay by itself. So the output of the OP AMP is connected to a power MOSFET. This transistor is used to turn the relay on and off.
I added a diode, a capacitor and a resistor to the input of the control circuit to help filter out noise and to smooth out the pulses from the radio receiver. This prevents the control circuit from rapidly turning on an off.
The control circuit is powered by a 12 volt battery pack.
When assembling the circuit, I first prototyped it on a breadboard. To test the performance of the circuit, I connected an LED to the output. Once I was happy with how the circuit was working, I soldered it onto a printed circuit board.
Step 6: Create an Adapter to Power the Receiver (optional)
The control circuit requires a battery and the receiver requires a battery. If they use the same voltage, then you can just connect them together in parallel. But if they require different voltages, then you either need two batteries or you need to make an adapter for one of them.
In this case, the receiver required 9 volts and the control circuit required 12 volts. So I used a voltage regulator circuit to bring the 12 volts of the control circuit battery down to 9 volts. This let me power them both with one battery pack.
I used an LM317 variable voltage regulator. This chip uses two resistors to set the output voltage according to the formula: Vout = 1.25 x (1 + (R2 / R1)). Using a 1.5kohms and a 240 ohms brought the output down to about 9 volts. Then I used a 9 volt battery connector to connect it to the receiver.
Step 7: Add a Latching Switch to the Transmitter
If your transmitter is activated by a momentary switch, then you need to replace it with a latching switch. That way the transmitter will stay on without you having to hold down the button. In this case, I am using the call button on a walkie talkie.
Locate the button. Then desolder the wires from the button. Next, solder a latching switch in its place. I recommend using heat shrink tubing to insulate the connections.
Now you need to cut a slot in the side of the housing for the new switch. Hold the switch up to the side of the housing and mark the two ends of the switch. Then us a sharp knife to cut a slot that us just big enough for the slider on the switch.
Lastly glue the switch in place. Be careful to not accidentally glue any of the moving parts on the switch.
Step 8: Attach the Relay
I am using an automotive relay. These typically mount to a special automotive relay socket. But you can also use individual 12-10 gauge quick disconnect connectors.
First we need to connect the relay to the control circuit. Take two wires and strip the insulation off of the ends. Solder one of the wires to the output of the control circuit and solder the second wire to the ground (negative terminal) of the control circuit.
On the other end of the wires, crimp on the 12-10 gauge connectors. Connect these to the terminals on the relay that are attached to the relay's coil.
Now you need to attach the device that you want the remote kill switch to control. In this case that was a power wheels car. I cut one of the wires that goes from the battery of the car to the power switch. Then I stripped the insulation off of the cut ends and crimped on another set of connectors. I attached one of these connectors to the common terminal on the relay and I attached the other connector to the "normally open" terminal on the relay. With this setup, the battery of the car will be disconnected until our circuit activates the relay. This way if the car goes outside the range of the remote, it will automatically turn itself off once it stops receiving the signal from the transmitter.
Step 9: Mount All the Parts
The last step is to mount all the parts to the device that is being controlled. Fortunately, there was a lot of empty space in under the hood of the power wheels car. So I attached all the components to the walls with duct tape. You want to make sure that everything is secure so that the parts don't bang around when it starts to move.
Step 10: Use Your Remote Cutoff Switch
Now you are ready to use your new remote cutoff switch. Turn on the transmitter and the receiver. Then flip the switch on the transmitter to begin sending the control signal to the receiver. The car should turn on. When you want to turn off the car, you can just turn off the transmitter. The car will also turn off if it goes outside the range of the transmitter.
Keep in mind that this system is susceptible to various kinds of interference. You should not rely solely on this system to keep you or anyone else safe. Even with this kill switch, You should still keep a close eye on your kids and be prepared to run up and save them if they need it.
Step 11: Alternate Design
If you don't want to mess around with hacking and modifying a pair of walkie talkies, you can just buy a commercially available remote controlled relay. I have used this one that I got from Fight Props and it works pretty well. Because it works at a higher frequency than walkie talkies, it is less prone to interference.
The only down side is that the relay latches on and off. So you need to manually turn it on and off. You can't rely on it automatically shutting off when it goes out of range.
Remote Control Contest
Finalist in the
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    16 Comments
    so that's who has been jamming my 900 MHz and/or 2.4 GHz baby monitors, wireless cameras, Wi-Fi, cordless phones and microwaves.
    just kidding.
    although I was kind of happy and annoyed when I was 6 - 10 as I found out that my walkie-talkies were on the same frequency as the baby monitor ( even after the replacement from the recall came). and if I'm remembering right I think the cordless phone was on the same frequency or at least could be as it had 10 of them. oh the days of unencrypted communication.
    I do have to say that this is a cool project, that I will probably end up doing myself someday?
    Can it be used on dogs, children and husbands, too?
    There is a product... Invisible Fence for dogs. I know of one father who used it in a creative parenting way on his children to keep them in the yard. He is currently in jail for child abuse.
    Nice build! I built a Toylander for my daughter and did a similar thing, however just used a very cheap 433MHz transmitter/receiver from ebay - 2 button controller that looks like a garage door opener. It also had 2 separate relayed outputs so I used one button to activate a buzzer so I could warn her she was heading where I didn't want and the other button to cut out the motor. Rather than putting the relay on the high current motor circuit I put it on the throttle circuit so that activating the cut out is the same as taking your foot full off the throttle. The reason for this which some people should be careful of is that some of these electrics cars (including the one I built) use regenerative/electric braking i.e. when you take your foot of the throttle the speed controller actually uses the motor(s) as dynamo and feed charge back into the battery - although the main reason is the braking force this creates. If you break the high current motor circuit, any vehicles with this sort of braking will glide to a stop slowly rather than braking to a halt quickly (which is probably what you want when your child is about to drive into a lake!)
    Do you think you could include any more information about this project? I've seen those modules, but haven't really experienced any simple applications that didn't require an Arduino. Bonus points for making an Instructable on the radio communication part!
    Hey this is an amazing idea! Never thought of it before. Thaks!
    If you could make this look like a sonic screwdriver, that'd be fantastic!
    (references)
    Nice! I like how simple an versatile this is. You have my vote.
    Cool project, you really killed it!
    Nice project, well done. Gotta keep the kiddos safe!
