Introduction: Remote Rocket Launcher Android
Picture of Remote Rocket Launcher Android
I have built a model rocket launcher that is wireless. I have been using my custom launcher for some time and I get tired of dealing with the long wire that always seem to get tangled.
I decided to build I wireless controller with an arduino and an android device that would launch the rocket from a distance without all of the long cables. This project was fairly cheap costing under $20.
For the wireless controller I used the following components:
Arduino Uno (Mini/micro will also work) - $5.99
HC-06 Bluetooth Module - $3.50
1ch Relay - $3.75
8x AA Battery Holder - $1.29
Toggle Switch (for case) - $2.10
2 Wires with alligator clips at one end and a box to put it in.
Tools:
  • exacto knife
  • soldering iron
Step 1: Build the Controller
Picture of Build the Controller
First you will need to wire up the HC-06 bluetooth module. Connect ground to one of the GND pins on the arduino and connect the TXD to the RXD and the RXD to the TXD.
NOTE: I found it helpful to put some type of switch between the VCC on the HC-06 and the 5V on the arduino. If you do not do this you will have issues reprogramming the arduino with the HC-06 connected. Have the switch open (off) to program and closed (on) during normal operations.
Next wire up the relay. Make sure the pin marked S on the relay is connected to pin 8 on the arduino. After the relay is connected to the arduino you can wire the negative terminal on the battery to the common terminal screw on the relay.(This is normally the middle one)
Step 2: Program the Arduino
Below is the sketch I used.
//Remote rocket launcher ***JDBWizzard***
int firePin = 8; //Pin connected to relay
void setup()
pinMode(firePin,OUTPUT);
Serial.begin(9600);
void loop() {
if(Serial.available()>0)
if(Serial.read() == 'l') //Lowercase L sent from android app
digitalWrite(firePin,HIGH);
delay(2000); //Can be raised if not firing
digitalWrite(firePin,LOW);
Step 3: Put It All Together
Picture of Put It All Together
Now that you have the controller together and programmed we need to put it together.
Take the box you choose to hold everything and make a hole to feed the ends of you wire without the alligator clips through. Connect one wire directly to the positive lead on your battery pack.
Mount the toggle switch somewhere on the box. Connect the other wire to one lead on the toggle switch. Now connect a piece of wire from the other lead on the toggle switch to the terminal screw on the relay label NO (normally open).
To power the arduino you could wire a male DC jack to the battery pack and plug it in to the connector. I will be opting to use a battery backup for a phone and connecting it with a usb cable.
Step 4: Download the App and 3..2..1....LAUNCH
Picture of Download the App and 3..2..1....LAUNCH
You can download the app from the google play store called Remote Rocket Launcher.
You can find the source code here. Fell free to build on it or make any changes.
Source code for the app will be available soon. You can use any app for arduino bluetooth as well. After you connect you just need to send l (Lowercase L) to the arduino to launch.
To test i used a LED with a 100ohm resistor instead on an igniter.
Enjoy.
SonjaC8 (author)2017-05-10
I was not sure how you were powering your arduino from the schematic.
If you are using this in the field, do I also need a 5v power supply, (in addition to the 12v. that runs triggers the ignitor? Thanks.
jdbwizzard (author)SonjaC82017-05-10
Yes I had a 5v power bank for charging a power to power the arduino. I found the the igniter draw all the current available then shuts down the arduino when trying to power the two from the same source.
seamster (author)2016-10-01
Very nicely done. Good, straightforward instructions too!
About This Instructable
3,045views
58favorites
License:
More by jdbwizzard:Nitduino AltWizz Arduino Rocket Altimeter ComputerRemote Rocket Launcher Android
Add instructable to:
