3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remote control color changing pumpkin
Halloween is only a few days away. We're getting into the spirit by building a remote control color changing pumpkin. Channel buttons 0-8 on the remote toggle the colors of the rainbow. Button 9 activates an 'angry pumpkin' mode that flashes a scary red strobe for a few seconds.
It uses a minimal PIC 18F2550 circuit that decodes the remote control signals and drives a ShiftBrite color changing LED module. The F2550 is a USB PIC with a USB bootloader, so it's technically a USB upgradable pumpkin too.
Happy Halloween from Dangerous Prototypes!
Step 1IR receiver
IR receiver
A PIC 18F2550 microcontroller decodes RC5 infrared remote control signals, and sends instructions to a ShiftBrite color-changing LED module. We used a PIC development board with SMD parts, but you could also build this on a breadboard or perf-board with through-hole parts.
The IR receiver converts infrared light from the remote control into a signal that the PIC microcontroller can decode. The receiver is connected to PORTB pin 2 (RB2) of the PIC. RB2 has an external interrupt with edge select that we used to trigger the IR decoder. RB2 also has a Schmitt buffer that cleans the incoming signal and helps prevents false triggers. All PORTB pins on the 18F2550 have internal pull-up resistors if your receiver is an old type that doesn’t have it’s own pull-up.
2 comments
Oct 30, 2009. 6:48 PMKiller~SafeCracker says:
Or you could just put one of those lights you can get at wal-mart for a buck.
Nov 11, 2009. 9:13 PMpossum888 says:
But then where would the fun and excitement of being creative be! Nice job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
128
Author:ian(DangerousPrototypes.com)
