loading
Step 5: Instal It!
Once it was assembled onto the door a rain cover was made from twinwall plastic sheet and a piece of electrical ducting, this too was installed.
A quick bit of wiring up to a 12v battery had the ram going in and out and the limit swiches were adjusted.
<p>The circuit would be the same as the <br>drawing in the instructable, the brackets would be simpler, a hinge at <br>the back fitted to the frame, a plastic block that the actuater rod <br>passes through to keep the rod in line.</p><p>Another bracket fixed to <br>the door with a strong magnet mounted to it and a piece of flat steel <br>mounted on the end of the actuater that touches the magnet and pulls the <br> door open.</p><p>It only needs to open enough for the dog to pass <br>through then pull it closed using the magnet. Mounted as suggested the <br>door can be used as normal by pulling it off the magnet. You would need <br>to ensure that the door latch is disabled while using the opener.</p><p>Hope that helps :)</p>
I like the way you designed your dog door. I am not good with electronics and would like to make something similar for a sliding door. Would you be willing to help me with this project?
You might be interested in checking out the website petgadgets.com and looking for the product I invented called &quot;EasyOut&quot; remote control pet door opener. It will be available for sale next month for wire crate doors, and later for hinged door flaps (like are commonly used in exterior doors), chain link kennels, and also plain wooden doors with sliding latches. There are links to videos for all 4 of these applications that you can watch in action on the above web site.
Very Cool! I need something like this, but haven't got around to do it yet. I think I would just have the door automatically close after a few seconds. I was wondering about the latch though. anybody could open the door and walk in with the magnet being all that's holding it shut. What about a solenoid operated latch? I was thinking too, though I don't know anything about electronics, what if your dogs had a coded transmitter on their collar so that only they could open it?
Hi Heath, some good questions! :) When the dogs have learnt to open the door I will include a timer to auto close. George has already learnt that he can bat the door off the magnet, fortuneately I had forseen this...I have had BMD's before :) all I need to do is drive the door fully open and it will pick up the magnet again for closing.<br> <br> I do have a 12v catch (see picture below) I have yet to work out how to route out the plastic door to fit it..... a bit scared to do it TBH :)<br> <br> The coded transmitter idea would indeed work but I was trying to keep the cost down as much as possible.<br> <br> Regards rog8811
That latch looks like a serious piece of hardware. What about a surface mount latch? Less invasive to the door you know.
There is not enough room for anything other than an inset catch, this one isn't that large, it is designed to be back mounted or inserted in the door by swapping to the plate on the left side of the photo, see below.
Your puppy is adorable! I have a Bernese mountain dog too!!!
lol... I <em>thought</em>&nbsp;that was a baby Berner! ;-)<br> <br> OMGosh... he's certifiably adorable!!!&nbsp;
He is a total cutie and getting bigger every day, a dog flap was never going to last the distance!
About This Instructable
30,025views
66favorites
License:
Bio: Woodsman and field tutor on a week day. Life long inventor, designer, engineer for the rest of the time. From items that make life easier ... More »
More by rog8811:Happy Fox! (First Element of a Large Project) Pocket 7 colour laser wooden truck with self tipping and motor noise
Add instructable to:
