Remote Control School Bell
Published
Introduction: Remote Control School Bell
About: Hello, I'm Bruce. I'm a student in Belgium. I have a wide variety of interests: electronics, computers, technology, ... In my spare time I spend a lot of time on: projects, exploring the internet, cycling. ...
What you'll need:
- a wireless doorbell
- 1 x transistor (like bc547)
- 1 x relay
- 1 x 1K resistor
Tools:
- some solder
- a soldering iron
Step 1: How It Works
Normal:
When you push the button
=> The remote sends a signal.
=> The doorbell receives  the signal and makes a pin high in an IC on the PCB.
=> That pin TRIGGERS the sound controller.
=> The sound controller sends a signal to a speaker.
=> The speaker makes an annoying sound.
Hacked:
When you push the button:
=> That pin TRIGGERS our new circuit.
(the transistor lets a current flow so the relay can switch on).
=> The relay switches on and lets a current flow trough the school bell.
=> The school bell rings "tringggg!!!!!!!!!!!! ".
=> And you can leave the class :D
Step 2: How to Find the Trigger Pin
Use the flowchart
Step 3: Making the Circuit
V+ is connected to the positive lead on the battery-pack of the doorbell.
GND is connected to the negative lead on the battery-pack of the doorbell.
Trigger
is connected to the triggering pin of the doorbell.
G5-8 = are normal battery's
R1 = 1KOhm
D1 = A normal diode like 1n4007 or 1n4004
K1 = NO relay 5V
T1 = A standard transistor like BC547
Step 4: Testing
When the school bell is not connected you can hear the relay switching when you push the button.
And when everything is connected the bell will start ringing when you push the button till you lose the button.
April Fools Contest
Finalist in the
April Fools Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    9 Comments
    heej kzie da je nederlands spreekt ^^ ik snap het niet zo goed zou jij het mij in het nederlands willen uitleggen?
    wat begrijp je niet? ik spreek ook nederlands :P
    STOP! I can´t understand... why your said "NO RELAY 5V"?
    Did you can put a picture of the PCB? `cos .. i dont understand how put the components :D PLS!! :D
    it doesn't make sense how you put the components on the pcb just make the right circuit
    NO RELAY = Normal Open RELAY
    http://www.structuredhomewiring.com/Images/NormallyOpenNormallyClosedCircuit.gif
