Introduction: Remote Controlled Relay
Picture of Remote Controlled Relay
In this project I am going to show you how to make an cheap remote controlled relay with an transmitter and receiver. This wireless relay can be used on anything and you can prank your friends by connecting it to an lamp and scare them ;)
Step 1: Parts and Tools
Picture of Parts and Tools
Here are the parts I used for this project, There are some parts in the photo that i did not use.
PARTS:
* Prototype PCB ( http://www.ebay.com/itm/251816892517?_trksid=p2060... )
* 9v relay module ( http://www.ebay.com/itm/1-Channel-Relay-Module-Wit...31411198006?pt=LH_DefaultDomain_0&var=&hash=item4d29a59036 )
* 2x 9v batteries
* 2x 9v battery clips/holders ( http://www.ebay.com/itm/2x-9V-Volt-Battery-Clip-Ha... )
* 3mm red LED ( http://www.ebay.com/itm/LOT-OF-20-50-100-3mm-Red-G... )
* 3k OHM resistor ( http://www.ebay.com/itm/50-pcs-1-4W-0-25W-5-Carbon... )
* 3x male headers ( http://www.ebay.com/itm/Enduring-Trendy-HOT-Light-... )
* 3x female headers ( http://www.ebay.com/itm/New-4PCS-40Pin-Straight-Fe... )
* SPDT slide switch ( http://www.ebay.com/itm/20pcs-Mini-SPDT-Slide-Swit... Position-3-Pins-/221668364697?pt=LH_DefaultDomain_0&hash=item339c76d199 )
* 25cm copper wire
* small antenna (from an RC car remote)
* push button ( http://www.ebay.com/itm/High-Quality-30pcs-6-6-H4-... )
* Wireless transmitter and receiver ( http://www.ebay.com/itm/New-For-Arduino-ARM-MCU-WL... )
TOOLS:
* Soldering iron
* Soldering tin
* PCB cutter
* Screwdriver (for making the antenna)
* Hot glue gun
Step 2: Prepare the Parts
Picture of Prepare the Parts
You need to desolder the terminal blocks on the relay module (if yours has any) and solder tree male headers instead, do the same with the transmitter.
Step 3: Schematic
Picture of Schematic
Follow the schematic when soldering the project.
Step 4: The Transmitter
Picture of The Transmitter
Solder on the parts like shown in the photos
Step 5: Wiring
Picture of Wiring
Solder on the power wires and the rest of the wires on the remote, use an tick wire for the antenna connection.
Step 6: The Antenna
Picture of The Antenna
To make the antenna I used an 25cm long copper wire and twirl it around a screwdriver like shown in the photo.
Step 7: The Receiver
Picture of The Receiver
place the parts on the PCB and solder them on like shown in the photos, the antenna is a little bit hard to do because you have to thread it into two pin holes and solder it on the ANT connection on the receiver board.
Step 8: Glue
Picture of Glue
Heat up your hot glue gun and glue the battery clip to the pcb so that its stuck and don't fall off when you connect the battery. Glue the emitter to the battery holder.
Step 9: FINISHING
Picture of FINISHING
Put the battery in the holder and screw the antenna on, than connect the receiver to the relay module and connect the 9v battery to the clip.
Now your ready to hack lamps, prank friends and the imagination is the limit.
Step 10: Video
here is an vide of the project in action and hopefully you get the same results :)
THANKS FOR VEWING!
IIf you like this project than go check out my channel for more projects that you might like, and if you have any questions or tips for this project than make an comment or send me en massage. If you have made any of my projects than please share an photo of it in the comments :)
LashaG (author)2016-02-21
Hi, have you any experience using PVM input in transmitter and servo on reciver ?!
signas (author)2015-11-18
Hello. I am trying to make this project using 12V relay with a 12V battery. Unfortunately when I press the button the relay does not react. Maybe i should use a different kind of a resistor?
ibenkos (author)signas2015-11-19
Maby it will work if you use a 5v regulator transitor for the receiver module so the 12v gets down to 5v.
dgatchalian (author)2015-11-18
can i change the copper antenna nto a transmitter antenna ?
ibenkos (author)dgatchalian2015-11-18
I don't really know much about antennas and lenght of them and materials but you could just try it out and see if it works. There are some sites that can calculate your antenna, depending on the Mhz and the range.
Can i use 3v battery instead of 9v?
Do you mean on the remote or the receiver?
I think the emitter will work on 3v but than I think the range would be weaker.
ibenkos (author)2015-10-20
I dont have an Android phone so I cant make a bluetooth app to do that or something like that.
Yes but for that you need an microcontroller like an Arduino that you have connected with 20 or 10 buttons at the TX, than the RX would need an Arduino with all of the signal pins connected to it.
irishchaos (author)2015-02-05
20 parts and it only costs $1 dollar? 2 batteries alone would put you over 1 dollar.
ibenkos (author)irishchaos2015-02-05
I did not mean that the project cost me 1$ but the receiver and transmitter costs 1$ (the two small boards)
jefferdomd (author)ibenkos2015-08-31
I could do that below cost $1.. ;)
honey181 (author)2015-04-26
Hey ibenkos, check out my new instructable i.e, increasing the channels on this 433MHz RF module. You asked me to share it, so here's it.. ;)
ibenkos (author)2015-04-20
thaks for the offer, I will think about it :)
Akshay Jha (author)2015-04-06
i like this and also voted this instructables because it`s very simple because sometimes we require only one channel in that case it is best
ibenkos (author)Akshay Jha2015-04-07
Thank you so much for the vote :)
honey181 (author)2015-03-28
Sure! :)
honey181 (author)2015-03-26
Its a nice and clean project. I'm too having the same trans. & receiver module. I'm going to use encoder and decoder ICs to increase the channels. :)
ibenkos (author)honey1812015-03-28
If you do so than please share your project, I want to learn how you can do that :)
tomatoskins (author)2015-02-05
I love this type of stuff! What is the range like on this?
ibenkos (author)tomatoskins2015-02-05
it depends on the voltage you power the transmitter with, and i think its 10m without any interference with phones and radios.
Coolnventions (author)ibenkos2015-02-28
How high can you max the voltage without frying it?
ibenkos (author)Coolnventions2015-03-20
I think it is 12v but you can read it in the descriptions for the item online
irishchaos (author)2015-02-06
Can you tell me how to connect this to a lamp?
ibenkos (author)irishchaos2015-02-06
The second image on the intro shows how I did it ;)
ade angelis (author)2015-02-06
You've just given me an idea on how to do something I was planning to do in a completely different and more complex way! Thank you for sharing this!!
ibenkos (author)ade angelis2015-02-06
No problem :)
gada888 (author)2015-02-05
Nice sharing
BeachsideHank (author)2015-02-05
Heisann, hvor er toalettet?
Hmm, I'd better stick to English, Google translate can be tricky. ;-)
Valuable Instructable, I like your procedures and craftsmanship, keep up the good work.
ibenkos (author)BeachsideHank2015-02-05
haha, funny ;) and thanks :)
About This Instructable
23,659views
226favorites
License:
Bio: I am always making electronic stuff. I like to do Arduino projects best. more projects coming soon!
More by ibenkos:433MHz 4Ch Remote ControllerWireless Robotic Control Hack a servo
Add instructable to:
