3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Remove Broken Light Bulbs Without Getting Cut or Shocked Using A Water Bottle
Step 3Remove the Broken Light Bulb
GET OUT OF THE WAY
GET OUT OF THE WAY
GET OUT OF THE WAY
GET OUT OF THE WAY ...
... when you push and twist so you don't get glass on you. If you've ever had glass lodged under your skin or in your eye you'll know why I repeated that four times. Again, learn from my mistakes here.
Congratulations, now you've removed the entire bulb without getting cut or electrocuted.
PS if you put a tiny bit of petroleum jelly on the threads of the new bulb it will be easier to take out when it burns out next time.
10 comments
Jun 23, 2009. 8:43 AMtommck says:
Why not unplug it and use needle-nose pliers?
Jun 23, 2009. 11:14 AMtommck says:
At the time I commented on this, there were 10 comments, so, I did do that.
Feb 22, 2009. 10:52 PMawlakers says:
stir stick for stirring paint is what i've always used..fits perfect.
Feb 11, 2009. 11:28 AMblodefood says:
I have heard that you can also use a hard vegetable like a potato to remove a light bulb base. Just make sure the fixture is unplugged first and there is no moisture left after the potato is used. Cut away the embedded part and throw the rest in the compost.
Feb 5, 2009. 6:49 AMcyberpageman says:
Petroleum jelly is an insulator, so don't use too much to lubricate the bulb threads.
Feb 5, 2009. 11:15 AMcyberpageman says:
That sounds good--just enough to put a thin film on the threads.
Feb 5, 2009. 7:51 AMJayDub says:
Thank you! Brilliant!
Feb 5, 2009. 6:22 AMrtermaat says:
Thanks, I have 2 broken lights and have just been doing nothing for 6 months.
Feb 5, 2009. 5:28 AMbaztastic says:
I've also found that a similar effect can be achieved using a carrot, although yours seems a bit more re-usable.
Feb 5, 2009. 5:49 AMSnillet says:
Does that mean we should be looking forward to a carrot-tastic instructable?
Jan 28, 2009. 1:47 PMezuk says:
Brilliant! I'm gonna try this some day.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:prabbit22m
I would love to find a job where I could play with fabrication tools all day and be creative. Anyone have a suggestion?
