Remove Broken Stereo Jack From Kindle
2,968
15
10
Published
Introduction: Remove Broken Stereo Jack From Kindle
I stupidly broke off a 3.5 mm stereo jack inside my Kindle Fire.
Doh!
Here's how I got it out.
Step 1: Open the Kindle
  1. Make sure the Kindle is off.
  2. Cut up an old credit card (or something like one) to use as a case cracker.
  3. Insert it into the crack along the side of the Kindle. I had to use a knife to get it started. Note: you may be voiding your warranty or risking damage to your Kindle. Your results may vary. The author is not responsible for anything awful that happens if you try this. Really.
  4. Run the credit card gently around the edge. You'll hear clicking sounds as the shell comes apart.
  5. Carefully lift off the back.
Step 2: Here's the Culprit.
This is what we're going to pry out.
Step 3: Pop It Out
I used a miniature screwdriver (the kind you use for eyeglasses) and slid out the broken jack.
Step 4: Put the Case Back Together
  1. Gently put the case back together (make sure it's the same way as it was before you took it apart, right?).
  2. Push along the edges. More clicking. You'll know when it's back together.
Step 5: Test It Out
Here we are with new headphones. They work. Yay.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    10 Comments
    Great guide just one point don't put screen side on a hard floor (like tiles) you can crack the screen, put it on a folded towel, found a fridge plastic ice scraper works too
    had* and tries* :( my Swype dictionary got reset so I have to pay more attention to spelling.
    mt can't find an edit option
    I ha add this happen to my s6. a plastic cotton swab and super glue worked in 2 tires.
    A guitar plectrum is a really useful tool for opening cases like this. Phone repair kits are available from Ebay very cheaply. They have all sorts of tools for opening plastic cases without damaging them and are handy to have around "Just in case". Great for phones, laptop bezels, satnavs - and Kindles!
    Glad you were able to fix your Kindle so easily!
    Thanks. I actually wound up trying a lot of failed ideas first (little drinking straws, epoxy, crazy glue, hot glue…).
