Remove Burned Fat Film From Oven Glass.
1,455
6
Published
Introduction: Remove Burned Fat Film From Oven Glass.
About: I'm aircraft -mechanic/-technician/-electrician (Avionic), I'm also a common electrician. (Fokker 70/100 & Airbus A320 series) I found interest in TIG (WIG) Welding. Arduino Raspberry programming. OBD codin...
(as you can see, I still have removed the most of the stain)
I tried to clean it with oven cleaner, with the green side of a sponge and I tried several cleaners without success.
the whole glass was like this brown spot.
I want to show you, how easy it is to clean the glass.
It is helpful to remove the door before u start.
in most cases this is easy, just half open the door and pull it away from the hinge.
if u have doubts, take a look into the manual of your oven.
Step 1: What You Need
-water
-a sponge or paper towels
-a dishwasher tab
Step 2: Cleaning
moisten the surface and rub the film with the tab. After that just rinse the glass.
You will see how easy and fast it is.
And the best, the glass doesn't get scratches.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Pets Challenge
      Pets Challenge
    3 Comments
    This worked! 5 year old regulary burned in fat on the oven door and its gone. I used the tab like a sponge und scrubed hard. I can finally see through shining glass into the oven :D thank you so much (no oven cleaner or fat remover could remove even a layer of it)
    Thx for your feedback.
